32
It is sometimes said, that if you stand still (in space), you travel through time at the speed of light. On the other side light never stands still, so it always only travels through space (at the speed of light), but not through time. Does that mean, if our universe would be filled with light only, no time would exist? Is the existence of mass therefor necessary for the existence of time?
asmaier
  • 10,250
7 Answers7
36
A universe containing only light is simply a radiation dominated FLRW universe. Indeed our universe had approximately this geometry in its radiation dominated era. The FLRW metric is a perfectly good spacetime, so time certainly exists. Moreover the geometry is time dependent so we can use the energy density as a measure of time.
I concede that it's hard to build a device capable of measuring time in a universe containing only light, but to claim that time does not exist in such a universe would be plain wrong.
bright-star
  • 373
  • 14
John Rennie
  • 367,598
22
Speed has a definite meaning, i.e. , the absolute value of the velocity vector, which is given as $({\rm d}x/{\rm d}t,~{\rm d}y/{\rm d}t,~{\rm d}z/{\rm d}t).$ There is no mathematical meaning in the phrase "you travel through time at the speed of light".
No. Entropy would still be defined by its statistical definition, and an arrow of time would exist.
Is the existence of mass therefore necessary for the existence of time?
Not of massive particles. As long as there is energy in its general relativistic meaning
$$m_0^2c^2 = \left(\frac{E}{c}\right)^2 - ||\mathbf p||^2$$ in natural units, where $c =1,$ $$m_0^2 = E^2 - ||\mathbf p||^2\,.$$
there will be an invariant mass of the photons comprising the light. In addition recent studies show that an arrow of time exists just because of gravitational interactions .
anna v
  • 236,935
14
I think you are becoming confused with the notion of proper time. Proper time is a measure of how much passage of time is experienced by an object. When you say that an object sitting still travels through time at the speed of light, you are kind of right. Let me start by explaining this.
"Speed through time"
If we're not experiencing any forces (gravity does not count) due to other objects pushing us or somesuch, then we may consider ourselves as being still and everything else as moving. This is called a choice of reference frame. In picking this reference frame, we have our own measurements of spacial coordinates $x,y,z$ and of how much time has passed-- i.e. by looking at our wristwatch. We call these coordinates $(x,y,z,t)$.
An object's trajectory through spacetime can be represented by a velocity in this choice of coordinates. Without going into too much detail, the most natural way to express this velocity is by how far through space and how far through our time coordinate an object is travelling per second of time that it experiences. Remember, this is called proper time and we denote it $\tau$. This is how we would express an object's velocity through spacetime:
$$\left( \frac{dx}{d\tau}, \frac{dy}{d\tau}, \frac{dz}{d\tau},\frac{dt}{d\tau} \right)$$
Again without going into too much detail or technicalities (I can if you want me to, but I suspect that you probably don't have the necessary background), special relativity tells us the amount of time we have to wait for an object to 'experience' one second ($dt/d\tau$) as a formula of its speed as measured by us ($dx/dt, dy/dt, dz/dt$). This factor is often denoted $\gamma$.
$$\gamma = \frac{dt}{d\tau} = \frac{1}{\sqrt{1 - \left(\frac v c \right)^2}} \quad \text{ where } \quad v = \sqrt{\frac{dx}{dt}^2 + \frac{dy}{dt}^2 + \frac{dz}{dt}^2}, \quad c = \text{speed of light}$$
What you call an object's 'speed through time' may be thought of as the amount of proper time this object experiences per second of our own time. In other words, how many minutes pass on a moving stopwatch per minute that passes on our own? This quantity is $d\tau/dt = 1/\gamma$.
$$\frac 1 \gamma = \sqrt{1 - \left(\frac v c \right)^2}$$ This is actually the equation of a circle! $$\left(\frac 1 \gamma \right)^2 + \left(\frac v c \right)^2 = 1$$
So an object's 'speed through time' and speed through space (as measured by us) always lies on the edge of this circle:
Would time stop without mass?
As you can see, an object can either be moving quickly through space (again, according to us), or quickly through time, but not both. A photon has no mass and a consequence of this is that it is always moving at the speed of light. As a result, its arrow tip in the circle above is always pointing straight up, and so it experiences no passage of time; in other words, no proper time. (An interesting note as an aside here is that if the photon were theoretically an unstable particle which decayed, we could never observe the decay because time never passes for the photon!)
So what you are asking is whether time would 'stop' if the universe was all photons. While true that time would never pass for any of these photons, there are still some aspects of the universe's spacetime which we do not understand, and which depend on time. For instance, the universe is expanding. If the universe were all photons, then this could still happen, and would involve something changing about the universe as the time coordinate advanced.
So without any mass in the universe, there would be no passage of proper time (i.e. watches would never tick; biological processes would freeze) but there would still be a notion of time because the universe itself is changing with it.
Myridium
  • 1,407
  • 23
The symmetry of spacetime is the Lorentz group. This is the set of three boosts and three spatial rotations of special relativity. Light rays form a projective Lorentz group. In geometry a projective space is the set of rays that "blow up a point," where all of those rays are equivalent under length change. Light rays emanating from a point, both into the future and those coming in from the past have zero length. The zero length condition is equivalent to saying there is no proper time associated with a light ray or photon. This is the light cone of special relativity. This defines them as the projective spacetime defined at a point of spacetime.
In general relativity spacetime consists of patches of locally flat regions with Lorentz symmetry. The same holds here, where a set of overlapping regions with a projective Lorentz symmetry define general curved spacetime. As a result we can consider spacetime with projective symmetry or according to light cones. Spacetime symmetry itself is then a fibration over the projective spacetime.
We can then see the question is a bit nuanced. If we consider only light rays, we then have only zero proper time for massless particles that might exist on some of these null rays. We might have an operational definition of there not existing time. However, the projective spacetime has this principal bundle construction which defines spacetime as well. This means that while time has no operational definition according to a massive particle along a timelike geodesic or curve, time still has a sort of emergent definition.
Many solutions to the Einstein field equations are vacuum solutions that have no source. This means spacetimes, not all of them necessarily flat, can exist in general relativity that are vacuums with no mass-energy source for the spacetime curvature.
This is not correct. Space is not the same thing as time, and the symmetry between space and time is limited to Lorentz symmetry. That means that for some specific purposes we may compare the time dimension with the space dimensions. But time is fundamentally different with respect to space. The assertion of a travel at speed of light through time is true if you set c=1 as it is currently practiced for certain purposes.
There is some confusion which you can avoid by reading the second postulate of special relativity: light is observed as traveling at c, but it is not said that light is traveling at c. That means that you get two points of view: On one hand, light is observed as traveling through spacetime at c, that means through space and through time. On the other hand, the lightlike spacetime interval of light is zero. That means that the point of emission and the point of absorption are directly adjacent in spacetime.
The proper time of massless particles and of lightlike movements in general is zero, they are not generating any proper time. This is why massless particles alone cannot build up any time. One mass particle in the universe would change the situation: The mass particle would interact with the massless particles, and the interaction would take place on the basis that light is observed as traveling at c. There would be time.
But you can also think of time in a universe without any particles at all. Space expansion is a process which is working like a clock.
Moonraker
  • 3,173
-1
The time dimension would still exist. There just wouldn’t be any energy in it and nothing to experience the passage of time.
Greg M
  • 19
You seem to presuppose that time slows down for moving objects and stops for light, but this contradicts any theory. For instance, special relativity predicts that time SPEEDS UP for moving objects/observers:
http://www.people.fas.harvard.edu/~djmorin/chap11.pdf David Morin, Introduction to Classical Mechanics With Problems and Solutions, Chapter 11, p. 14: "Twin A stays on the earth, while twin B flies quickly to a distant star and back. [...] For the entire outward and return parts of the trip, B does observe A's clock running slow..."
