Is it just the distance between galaxies that increases? Or is the distance increasing between the molecules in my body? Does expansion affect universal constants?
Various sources I have heard on the topic of expansion seem to contradict each other. (at least in my mind) If a physicist says: "There's not enough gravity to prevent expansion" then it makes it seem like a simple matter of Newtonian physics; as if galaxies were flying off under their own momentum. But if a physicist says: "Nothing can travel faster than light EXCEPT for the expansion of space itself" then this makes it seem like the invisible fabric of space-time is stretching.
The space that you inhabit is expanding, but it is expanding slowly enough (~70 km/s/Mpc) that it doesn't have any significant effect at that scale. Even if you do think of this as "stretching" the bonds within molecules in your body, it's slow enough that everything can just go back to its equilibrium geometry.
To give you some idea of the rate of expansion, if molecules didn't go back to equilibrium geometry (they do), and everything within space also expanded (it doesn't), then over the course of a century, the distance between your head and feet would grow by about the length of a typical chemical bond (~$10^{-10} \text{m}$). A bond between two atoms would grow by ~$10^{-20} \text{m}$, which is a distance ~10 orders of magnitude smaller than the bond itself.
kevin
  • 28
