-1
I was thinking about the unit of measure of the Energy (as well as Heat and Work) which is Joule
$$\text{J} = \frac{\text{kg}\cdot \text{m}^2}{\text{s}^2} = \text{N}\cdot \text{m}$$
But again, watching the very last expression I realized that that is the same unit of measure of a vector quantity, namely the Torque or the Moment of Force.
How is that possibile, since the Joule represents a scalar quantity?
Isn't it a bit ambiguous?
EXVII
  • 3,783
There's nothing about units that makes them associated with scalars or vectors specifically. The difference between a scalar and a vector is the fact that the latter has components, but in either case, they can have any units.
David Z
  • 77,804
One is defined via a dot product, work $W = \vec F \cdot \vec r$ which produces a scalar quantity, and the other via a cross product, torque $\vec \tau = \vec r \times \vec F$ which produces a vector quantity.
Farcher
  • 104,498
Since work done $W$ is the sum of force $F$ applied in the direction of displacement $s$, i.e: $$W=\int F\cdot ds $$ we have work as a scalar quantity. Besides, unit defines a magnitude of a quantity, not whether something is a vector or scalar.
NaOH
  • 628
