I have been racking my mind over the double slit experiment. There are many excellent demonstrations of the double slit experiment, some with water, and some with light, available online. I am familiar with expressing a wave as:
$y_i(x,t)=A_isin(2πxλ_i)sin(2πf_it)$
and vartiants, so I have no problem envisioning and interference pattern. However, the analogy (if it is one) of light and water interference seems to break down to me because two sources of waves in the water can clearly create a diffraction patter with no slits. Two sources of light do not, in general,do the same thing, because I can turn on a few of my lamps and not get a diffraction pattern!
I know that the light sources are out of phase $\Delta\phi_0$, but could someone be so kind as to explain to me as to why they become in phase while passing through the slits?
Thank you kindly. (I have not seen two out of phase wave sources in water being made to pass through two slits.)
John Rennie
  • 367,598
Where I have seen it, the two-slit are used to "divide" in two sources a common source, in order to have two coherent sources which interfere in different positions because of their different paths toward the given point.
Theoretically any pair of sources will interfere, but for the pattern to be invariable in time, the sources must be coherent.
As to why it does not happen as with water, well it does. When you observe a wavy sea surface, where peaky forms rather than waves are visible, yo are observing chaotic interference between many waves of different frequencies and amplitudes. And it probably happens with light too, but the variations are so fast, and the photons so many that no deviations of the mean brightness is apparent.
rmhleo
  • 3,805
