Consider a two body system say the earth with mass $M$ and the moon with mass $m$ and distance $d$ between them. Thus there is a point in space between the earth and the moon where the force of gravity on an arbitrary object is equal in magnitude but opposite in direction. Similarly on the other side of the moon, there will be a point in space where the force of gravity on an arbitrary object is equal in magnitude but and identical in direction.
Question:
  1. What is the locus of all points where the magnitude of the gravitational force on an arbitrary object due to the earth and the moon is equal in magnitude regardless of the direction. Will it be an ellipse with the moon at one focus?
  2. What will be the path of motion of an object if it suddenly pops into existence with zero initial velocity on the above locus? Will it revolve around the larger body or will it revolve around the smaller body or will it revolve around their common center of mass or will it float aimlessly in space?
  3. How will the above answers change if we consider the two body system to be an isolated system with no external gravitational influence
Gravitational field is proportional to mass of object and inversely proportional to the square of distance to object.
$$G*M/R^2 = G*m/r^2 => R^2/r^2 = const => R/r = const$$
I remember from electrostatic course that the locus of such points is a sphere (or a plain iff $R=r$). It's not difficult to prove. Let $x, y$ be coordinates of a point, $M$ located as $(0, 0)$, $m$ located at $(0, a)$.
Square of distance to $M$: $x^2+y^2$
Square of distance to $m$: $(x-a)^2+y^2$
Now we have: $(x-a)^2+y^2 = C*x^2 + C*y^2$
And now we have an equation of the required locus of points: $$(C-1)*x^2 + (C-1)*y^2 = a^2 - 2*a*x$$
This must be a circle (because coefficients of $x^2$ and $y^2$ are equal). In 3-D space this would be a sphere. The sphere encloses the smaller body, but the body is not in it's center.
So, your first question was relatively simple. Question 2 seems to be much more difficult. Some clarifications are necessary: are the two massive bodies "fixed" in space or are they moving as well like Moon and Earth? If yes, is the third body large enough to disturb the motion of the first two ones? Each "yes" makes the problem more difficult. But I do not think there is a nice simple answer even in the most simple case (bodies are fixed).
And I do not understand Question 3. Wasn't this system isolated from external forces all the time?
lesnik
  • 4,242
Two bodies (like Earth and moon) can't be fixed if they are influenced by gravity force each other. They must orbit around a Mass Center. In this case this point are the Lagragian ones and they take into account also centrifugal force. If you want to find the position of L1 L2 L3 I've found a beautiful explanation here: (the page is in Italian, but there isn't so much text, so you can translate it simply with a online translator)
http://it.giocandoconlagravita.wikia.com/wiki/I_Punti_di_Lagrange_L1,_L2_e_L3
