Let's take the pendulum equation $\ddot{x} = -\sin x$. Here $x \in \mathbb{T}^{1}$. Now rewrite it as a coupled first order system $$\dot{y} = -\sin x, \quad \dot{x}=y.$$
Intuitively we know that $y$ corresponds to velocity, the norm of which (i.e. speed) can be as large or small as we want, thus $y \in \mathbb{R}$. Hence the phase space of the pendulum is the cylinder $\mathbb{T}^{1} \times \mathbb{R}$.
However $x(t) = x(t+t_{0})$ for some period $t_{0}$ and by the definition $ y =\dot{x}$ we also expect $y(t)=y(t+t_{0})$, i.e. we can say $y \in \mathbb{T}^{1}$.
Is this a contradiction? Why do we define $y$ to be in $\mathbb{R}$ and not in $\mathbb{T}$?
Alex
  • 331
$x\in \mathbb{T}^1$ denotes the structure of the phase space itself, not the fact that the motion as a function of time is periodic. Any arbitrary motion of the pendulum can be represented in the phase space, not just the ones periodic (in time). We have $x\in \mathbb{T}^1$ because you can rotate the pendulum around the hinge for a full cycle and you end up with the same state. You cannot say the same for $y$.
pathintegral
  • 1,572
  1. If the Lagrangian formulation has configuration space $M$, and the Legendre transformation is non-singular, then the corresponding phase space in the Hamiltonian formulation is the cotangent bundle $T^{\ast}M$. (For the pendulum, the configuration space $M\cong S^1$ is a circle.)
  2. For models with a 2-torus $S^1\times S^1$ as phase space, see this Phys.SE post.
Lagrangian mechanics is defined on a tangent bundle, the tangent bundle of the configuration space. For the pendulum the configuration space is $S^1$ the circle. Its tangent bundle is trivial, so it is $S^1 \times \mathbb R$.
You can pass to the Hamiltonian description, which lives on the cotangent bundle -- it too is trivial, so it is also $S^1 \times \mathbb R$. That is the space of initial conditions. The actual motion will be periodic in both variables, but that's something else.
(There is something called invariant tori, where the almost periodic motion traces out a torus in phase space. I'm not sure that applies to the pendulum.)
Robin Ekman
  • 15,017
Consider all possible motions of the pendulum, $x=x_I(t)\:, \dot{x}=\dot{x}_I(t)$ where $I=\{x_0, \dot{x}_0\}$ denotes the initial conditions of that solution of Hamilton equations. Varying $I$ you have all possible solutions.
Well, there is an evident asymmetry between the two Hamiltonian variables. $x$ can always be taken in a circle, as $-\pi \leq x \leq +\pi$ is enough to describe all motions of the pendulum independently from $I$. A larger interval would be redundant to describe the positions of the pendulum. Conversely, there is no sufficiently large interval $[-\dot{X}, \dot{X}]$ which may include all values of all functions $\mathbb R \ni t \mapsto \dot{x}_I(t)$ for every initial condition $I$. This fact holds even if every such curve $\mathbb R \ni t \mapsto \dot{x}_I(t)$ is periodic.
