This is a purely theoretical question about "perfect" solids under "perfect" conditions.
Assume you have a crystalline solid with a perfect crystal lattice (i.e. no defects). Let's imagine a cube of pure diamond, perhaps 2 cm^3 in volume.
Now imagine that this solid was perfectly cleaved along a perfect single plane, with no damage to the crystal lattice on the exposed surfaces. (i.e. The cube is split into two halves, exposing two perfectly planar surfaces with no damage or loss of material.)
Furthermore, for the sake of discussion, assume that the plane of cleaving is also perfectly aligned with one of the "natural" axes of the crystal lattice.
Given these two halves of the crystalline solid, would it be possible to "reassemble" them into the original solid by perfectly aligning the two halves and pressing them together?
Given that the "cleaving" of the original solid involves breaking the inter-atomic or inter-molecular bonds holding the solid together, it seems reasonable to suggest that the solid can be reassembled by placing the two halves in their original positions, and, by exerting sufficient pressure (or energy?), cause these bonds to re-form.
In essence, we are talking about re-assembling a solid crystal without any "glue", and ending with with a single solid indistinguishable, and just as "strong" as the original.
What physical properties would prevent this from working (under ideal conditions), or is it theoretically possible? If possible, how would the required force compare to the force of cleaving? Where does the energy expended during cleaving go, and how is energy re-absorbed during re-assembly?
For example, see cold or contact welding of ultraclean, similar metallic surfaces under ultrahigh vacuum conditions.
After a few such experiences with what I thought were cleverly designed friction fittings for some electron beam optics, I soon learned to either use different metals, or sprinkle a bit of dry molybdenum disulfide on the joints to dirty them up!
Of course, as the article makes clear, these are nano or micro crystals. You could probably get an article in Science if you could do it with silicon. Or maybe a patent. Entropy is against you, and gets worse as size goes up. You can actually calculate this. Expect to test for all of the many dislocation types known to crystallographers.
Peter Diehr
  • 7,367
One word answer: Yes! To add a little to Peter Diehr's reference to cold welding, here is a physically insightful argument that the answer to your question is yes due to Richard Feynman. He asks the rhetorical question: suppose we re-align the two halves so that all the atoms on either side of the cleave are in the same positions as they would be in the periodic lattice of a single connected piece of the same metal. Where then is the information that tells which former half of the rejoined piece each atom formerly belonged to? Or, more "teleologically": how does each atom know which half it formerly belonged to? Feynman deduces that there can be no difference between the re-aligned two halves and the single connected metal block.
Of course, this argument tacitly assumes that the states of all the delocalized electrons have reached the steady state that they would have in the single, rejoined piece of metal - witness that the steady states for the rejoined and re-aligned systems are indeed identical - and that there is no energy or other barrier to the electrons' reaching this steady state. If there were, then there would be an encoding of where the barrier lay.
But, assuming there is nothing stopping progress to the steady state for the electrons, the argument holds good. So it's not a perfect argument, but it is a simple, compelling one.
Selene Routley
  • 90,184
  • 198
  • 428
Yes it is theoretically possible. The things that prevent it from working are (1) Dirt / oxidation / etc. obviously; (2) Depending on the cleave plane and material, there may be surface reconstruction, which would most likely mean that the reassembled block will have a bunch of defects at the interface.
There should be no required force; they will rejoin spontaneously and release heat when doing so. The amount of heat released is (ideally) equal to the work expended when cleaving it earlier.
Steve Byrnes
  • 17,082
