Inspired by this question, I have slightly different question.
One way how photons are produced is through quantum oscillator transition from upper state $E_2$ to lower state $E_1$. The photon energy, and its wavelength is described as $$E_2-E_1=E_{ph}=h\nu_{ph}=\frac h \lambda_{ph}.$$
Suppose there is no "source" of photons from nothing.
  • Are there limits for the stransition steps, leading to limits for the photon wavelengths?
  • Are there othe sources of photons, that does't have such limits?
  • Is the presumption of nonexistence of photon "source" false?
Crowley
  • 1,244
As the comments mention, there is no practical lower limit on the energy. As to upper limits:
Photons can be produced by atomic transitions, and here, the drop of an electron from free space to the $1s$ orbital in a hypothetical stripped nucleus would set an upper limit. But then you can go to photons emitted from nuclear interactions (X-rays to Gamma rays) and those are much more energetic. Past that, at accelerators like Fermilab and Cern heavy particles created for an instant of time decay, often emitting "hard" gamma rays on the order of tens of GeV.
Cosmic events can yield even more energetic gammas than anything man has produced. A practical limit is set by the energy at which the gamma-gamma interaction (picture a 1-loop Feynman diagram with an electron mediating between two photons) of a hard gamma against a $3^\circ$ radiation photon becomes significant. For photons travelling intergalactic distances, this imposes a limit of about $10^{16}$ to $10^{17}$ eV. And we actually do detect events explained by such high-energy "gamma ray bursts"; in fact, some pretty much have to have originated in our own galaxy because otherwise they would have lost too much energy in collisions aginst the $3^\circ$ background.
Mark Fischler
  • 604
(This is point number 3) I'm not sure about what you mean with "source of photons from nothing": you can't create energy, so for example you need to provide the energy needed to your quantum system for going to $E_2$ first. Said that, the photon wasn't "inside" the system, it was created, 'from nothing' if you want.
  1. See the comment for lower energy limit. For an upper limit, if you give too much energy to your oscillator (how much depends on the system) you'll end up destroying it (tearing apart its costituents), so any theoretical upper limit (see the question you linked) is not very relevant.
  2. Yes, for example using Compton backscattering en.wikipedia.org/wiki/Compton_scattering. In this process, low energy photons scatter on high energy charged particles (electrons are best suited) and some of them gain a lot of energy. Notice that there you don't create photons 'from nothing', but instead transform already existent photons (altough is most correct to state that you are destroying the old photon and creating a new one).
    The limit here is basically the speed your electrons can reach (so it's about particle accelerators max energy, which grows as technology improves): for backscattering (the new photon goes in opposite direction than the old one, with the biggest possible energy), given the electron $\beta = v/c$, the new photon energy $E'_\gamma$ relates to the old $E_\gamma$ as $E'_\gamma = \frac{(1 + \beta)^2}{1 - \beta^2} E_\gamma$ (the formula is approximated but very good in this setting). E.g., 1.5 GeV electrons scattering on 2.5 eV photons yelds photons up to 100 MeV, so GeV photons and beyond should be achievable today.
