Consider the Lagrangian $$\mathcal{L} = \frac{1}{2}(\partial_{\mu}\phi)(\partial^{\mu}\phi) - \frac{1}{2} m^{2} \phi^2 -\frac{1}{3!}\lambda \phi^{3}.$$ Following Michio Kaku's discussion in his QFT book, I proved that the superficial degree of divergence is given by $$D = 4 - E - V,$$ where $E$ is the number of external legs of a diagram, and $V$ the number of vertices (I'm not completely sure this expression is correct, though).
Using this, I found that the diagrams which are superficially divergent and need to be regularized are the tadpole diagram and the self-energy (again, I'm not completely sure of this, so if I'm wrong by any means tell me, please). I then calculated both amplitudes and introduced counterterms in the Lagrangian in order to render the calculations finite.
However, I'm having serious doubts when adding the counterterm corresponding to the tadpole diagram, since apparently it has to be linear (for instance, the author of these notes (pdf) includes such a term). Is it correct to do this? My main concern is that, since there are no linear terms in my original Lagrangian, the tadpole diagrams do not survive, and my reasoning was that maybe I shouldn't bother to renormalize this diagram at all, since there would be no contributions due to it. Is my reasoning right? Or should I keep the linear counterterm? Any input will be much appreciated.
innisfree
  • 15,425
gradStudent
  • 286
  • 14
