I read that $U=q+w$ and $H=u+PV$ so aren't $PV$ and $w$ same? If they are, can't we write $H=q+2w$? Also, $dU=$ change in internal energy wrt change in temperature keeping $V$ constant times $dT+$change in internal energy wrt change in volume keeping $T$ constant times $dV$ Here is the second term $=w$? And, $dH=$ change in enthalpy wrt change in temperature keeping $P$ constant times $dT+$ change in enthalpy wrt change in pressure keeping $T$ constant times $dP$. Here is the second term $=PV$?
Asked
Active
Viewed 704 times
According to the sign convention you are using, $$\Delta U=q+w$$where, for a reversible expansion or compression, $$w=-\int{PdV}$$So, $$\Delta U=q-\int{PdV}$$and$$\Delta H=\Delta U+\Delta (PV)=q-\int{PdV}+\Delta (PV)$$Integrating by parts, we get$$\Delta H=q+\int{VdP}$$
The quantity $$\int{\left(\frac{\partial U}{\partial V}\right)_TdV}$$ is not equal to the work. In fact, for an ideal gas, this quantity is always equal to zero. Similarly for $$\int{\left(\frac{\partial H}{\partial P}\right)_TdP}$$
Chet Miller
- 35,124
