The Hamilton-Jacobi equation is: \begin{equation} H\left(q,\frac{\partial S}{\partial q},t\right)+\frac{\partial S}{\partial t}~=~0, \end{equation} where $S$ is Hamilton's principal function.
If we take a second-order $L$ such that $$L=L(\{q_j,\dot{q}_j,\ddot{q}_j\},t),$$ does the Hamilton-Jacobi equation change, or we could always consider that $$\displaystyle\frac{\partial S}{\partial t}=-H~?$$
Milou
  • 446
  • 17
  1. Let us suppress explicit time dependence $t$ from the notation in the following. Let there be given a second-order Lagrangian $$L(q,v,a); \tag{1}$$ where $q^i$ are positions, $v^i$ are velocities, $a^i$ are accelerations, and where $i\in\{1,\ldots,n\}$.
  2. We would like to find the corresponding Ostrogradsky Hamiltonian formulation. Let us for simplicity assume that the Hessian $$ H_{ij}~=~\frac{\partial^2L}{\partial a^i\partial a^j} \tag{2}$$ is invertible.$^1$ Then the Ostrogradsky Hamiltonian is defined as $$ H(Q,P)~:=~ p_iv^i + \sup_a\left(\pi_i a^i-L(q,v,a)\right) ,\tag{3}$$
    where we have introduced the collective notation $$Q^I~=~\{q^i;v^i\},\qquad P_I~=~\{p_i;\pi_i\},\qquad I~\in~\{1,\ldots,2n\}.\tag{4} $$
  3. In the spirit of my Phys.SE answer here, we introduce an extended Lagrangian$^2$ $$ L_E(Q,\dot{Q},P,a)~:=~p_i(\dot{q}^i-v^i)+\pi_i(\dot{v}^i-a^i)+L(q,v,a).\tag{5}$$ If we integrate out $P_I$, $v^i$ and $a^i$ in the extended Lagrangian (5), we get back the Lagrangian itself $$ L(q,\dot{q},\ddot{q})\tag{6} .$$ If we only integrate out $a^i$ in the extended Lagrangian (5), we get the Ostrogradsky Hamiltonian Lagrangian $$ L_H(Q,\dot{Q},P)~:=~P_I\dot{Q}^I - H(Q,P).\tag{7}$$ This implies that the higher-order Euler-Lagrange (EL) equations of (5) is equivalent to a standard Hamilton's equations in $Q^I$ and $P_I$! In other words, in the non-singular case (2), we can re-use the standard Hamilton-Jacobi (HJ) theory for this case! The only difference is that the phase space (4) is twice as big.
$^1$ If the Hessian matrix is singular, there will appear constraints, and the Hamiltonian formulation and the Hamilton-Jacobi theory become modified as a result.
$^2$ If we vary the extended Lagrangian (5) wrt. to $a^i$ and $v^i$, we get the Ostrogradsky momenta $$ \pi_i~\approx~\frac{\partial L}{\partial a^i} ,\tag{8} $$ and $$ p_i ~\approx~\frac{\partial L}{\partial v^i}- \dot{\pi}_i~\approx~\frac{\partial L}{\partial v^i}- \frac{d}{dt}\frac{\partial L}{\partial a^i} ,\tag{9} $$ respectively. [The $\approx$ sign means equality modulo equations of motion.]
