It is strange to me that for a symmetry which involves $\dot{x}$, there seems to always appear a term with $\dddot{x}$ in the variation of the equations of motion, which doesn't makes much sense. I think that probably the procedure I am following is wrong.
I will show you an example: Consider the simple case of a free particle in one dimension, it's Lagrangian is:
$$L=\frac{1}{2}\dot{x}^2$$
It is obvious that the system conserves energy, so the symmetry that must be valid is $(\delta x=0 ,\delta t=\epsilon)$. I may rewrite these as symmetries that doesn't involve time variations (as the paper by E. L. Hill do):
$$(\delta_{*}x=\epsilon\dot{x},\delta_{*}t=0)$$
Now, I calculate the variation of the equations of motion, with the hope of finding that $\delta(\text{e.o.m})=\text{e.o.m}.$ Such result would mean that the equations of motion are invariant under the symmetry in consideration. So:
$$\delta{(\text{e.o.m})}=\delta(\ddot{x})=\ddot{\eta}$$
In this case $\eta = \dot{x}$ (remember that a variation is of the form $\delta{x}=\epsilon\eta$). So $\ddot{\eta}=\dddot{x}$. Hence:
$$\delta(\text{e.o.m})=\dddot{x}\neq\text{e.o.m}$$
This doesn't make sense because, for the system in consideration, the time translation is a Noetherian symmetry that gives conservation of Energy.
My question is: What is failing in this procedure? Is there a general way of showing that some Symmetry is indeed Noetherian?
rsvdr
  • 872
Short answer: In the reduction (when showing that an equation of motion $EOM=0$ has a symmetry), one is also allowed to use consequences of $EOM=0$. E.g. in OP's example: $$\ddot{x}~=~ 0 \quad \Rightarrow \quad\dddot{x}~=~ 0,$$
See also e.g. this related Phys.SE post.
I'm not sure precisely what you did to solve this problem (for instance, how is the equation of motion, which is by definition an equation, also the quantity $ \ddot{x} $), but here's how I would approach it.
If we vary the Lagrangian according to the transformation you provide:
\begin{align} \delta L & = \delta \left ( \frac{1}{2} \dot{x}^2 \right ) \\ & = \frac{1}{2} \delta \left ( \dot{x}^2 \right ) \\ & = \frac{1}{2} \cdot \frac{\partial \dot{x}^2}{\partial \dot{x}} \delta \dot{x} \\ & = \frac{1}{2} 2 \dot{x} \delta \dot{x} \\ & = \frac{1}{2} 2 \dot{x} \delta \frac{\partial x}{\partial t} \\ & = \frac{1}{2} 2 \dot{x} \frac{\partial}{\partial t} \left ( \delta x \right ) \\ & = \frac{1}{2} 2 \dot{x} \frac{\partial}{\partial t} \left ( \epsilon \dot{x} \right ) \\ & = \dot{x} \frac{\partial}{\partial t} \left ( \epsilon \dot{x} \right ) \\ & = \frac{\epsilon}{2} \left [ \dot{x} \frac{\partial \dot{x}}{\partial t} + \frac{\partial \dot{x}}{\partial t} \dot{x} \right ] \\ & = \epsilon \frac{\partial}{\partial t} \left ( \frac{1}{2} \dot{x}^2 \right ) \end{align}
We now see $ L \to L + \epsilon \partial_{t} J $ for $ J = \frac{1}{2} \dot{x}^2 = L $. You can show that this always works out. Since the Lagrangian changed by only a total derivative, we have a symmetry, and you can show that the conserved charge is energy.
QuantumFool
  • 1,274
