Imagine you have a box full of a gas. It is at thermodynamic equilibrium.
The entropy of the gas in the box is proportional to the logarithm of the number of available microstates.
The number of microstates is proportional to the number of oscillators (abstractly speaking) times the number of available states per oscillator.
Let's limit ourselves to the translational case. In the ideal particle-in-box model, we know that the possible momenta of the particles is quantized, due to the boundary conditions imposed by the sides of the box.
If we were to put a divider in the middle of the box, half of the possible momentum states would now be disallowed. Previously, wavefunctions corresponding to each particle were allowed to have an antinode in the middle of the box ("odd solutions") but now can only have wavefunctions with a node in the middle of the box ("even solution"). There are now fewer translational microstates, so entropy should be reduced.
However, as far as I know, putting a divider in a box does not change the entropy.
A possible solution here is that perfectly rigid dividers and boxes don't exist; a particle can impart momentum into the divider, which can then be imparted to particles on the other side, etc., which would increase the effective number of microstates. However, we should still expect some reduction in available microstates, and this cannot be a complete explanation because we know that if we have two different gasses separated by a divider, by removing the divider we increase total entropy. This, and the fact that increasing volume increases entropy, is nicely explained by the fact that there are more available momentum states in a larger box. However, I cannot reconcile this with the "divider inserted into an equilibrium gas" example I gave above.
Edit: The proposed solution does not address the question in terms of additional momentum state density. I wouldn't even say it actually answers the question at all. "because the thin membrane doesn't materially change the system and carries a tiny entropy by itself. " is not an explanation, just a tautological re-statement of the question.
