20
Very related to this question:
Is it possible to go from the Master Equation formalism to Heisenberg-Langevin equations
I don't yet have enough reputation to comment so I'm asking the new question here.
I'm coming from a physics background on this question here. My question boils down to the following. On the Wikipedia page for the Lindblad Equation page for the Lindblad equation there are two equations:
$$\dot{\rho} = -\frac{i}{\hbar}[H,\rho] + h \left(L \rho L^{\dagger}-\frac{1}{2}\left(\rho L^{\dagger}L + L^{\dagger}L\rho\right)\right)$$ $$\dot{A} = +\frac{i}{\hbar}[H,A] + \frac{1}{\hbar}\left(L^{\dagger}AL - \frac{1}{2}\left(AL^{\dagger}L + L^{\dagger}LA\right)\right)$$
I've set $h_{1,1}=h$ and $h_{n,m}=0$ otherwise in comparison to the Wikipedia formulas to simplify things. I'm also curious if a factor of $h$ has been lost somewhere in the second equation but that's not my main question.
I want to know how to go from the first equation to the second. From user yuggib's response on the linked question it is clear that it is related to some duality between the space of density operators and the space of observables, but I'm not familiar at all with Von Neumann algebras or semigroups etc.
In their response in the linked question yuggib also writes down similar form for the superoperators to what is found on Wikipedia:
$$(\mathscr{L})_*\rho= -i[H,\rho]+\frac{1}{2}\sum_j\Bigl([U_j\rho,U_j^{\dagger}]+[U_j,\rho U_j^{\dagger}]\Bigr)\; .$$
$$\mathscr{L}X= i[H,X]+\sum_j\Bigl(U_j^\dagger X U_j -\tfrac{1}{2}\{U^\dagger_jU_j,X\}\Bigr)\; .$$
(I've directly quoted yuggib's equations so $L$'s have turned into $U$'s and there is now a summation.)
Similarly it is not clear to me how to go from the first line to the second. It seems a bit more explicit in this case that the two operations should be related (since they're dual in some way I don't quite understand..) however I don't see (computationally speaking) how the jump was made from one to the other. It looks like you just sort of take a hermitian conjugate in terms of how the super operator acts but why is that sufficient and/or necessary to ensure the dual behavior?
Thank you for any help with this.
In this reference on page 70 they make the same jump from the time evolution of the density matrix to the time evolution of the operators
Urb
  • 2,724
Jagerber48
  • 16,234
$\def\dd{{\rm d}} \def\LL{\mathcal{L}} \def\ii{{\rm i}} \def\ee{{\rm e}}$ The trick here is very simple and physically motivated. You simply demand that the expectation value of an operator $A$ is the same in the Schroedinger picture (density matrix evolves) and the Heisenberg picture (operator evolves). That is, $$\langle A\rangle = \mathrm{Tr}\left\lbrace A(0) \rho(t)\right\rbrace = \mathrm{Tr}\left\lbrace A(t)\rho(0) \right\rbrace,$$ where $A(t)$ [$\rho(0)$] is the operator [density matrix] in the Heisenberg picture, while $A(0)$ [$\rho(t)$] is the operator [density matrix] in the Schroedinger picture.
The Lindblad equation can be written in the Schroedinger picture as $$ \frac{\dd\rho}{\dd t} = \LL[\rho],$$ where the Liouvillian is defined by ($\hbar = 1$) $$\LL[\rho] = -\ii[H,\rho] + \sum_k \left ( L_k \rho L_k^\dagger - \frac{1}{2} \lbrace L_k^\dagger L_k,\rho\rbrace \right).$$ The formal solution of the Lindblad equation can then be written as $\rho(t) = \ee^{\LL t} [\rho(0)]$, where the exponential of the superoperator $\LL$ is defined as usual by its Taylor series expansion. Now, define the adjoint Liouvillian $\LL^\dagger$ by $$ \mathrm{Tr}\left\lbrace P \LL[Q] \right\rbrace = \mathrm{Tr}\left\lbrace \LL^\dagger[P] Q \right\rbrace,$$ where $P$ and $Q$ are arbitrary operators. It follows from the definitions that $$ \mathrm{Tr}\left\lbrace A(0) \rho(t)\right\rbrace = \mathrm{Tr}\left\lbrace A(0) \ee^{\LL t}[\rho(0)]\right\rbrace = \mathrm{Tr}\left\lbrace \ee^{\LL^\dagger t}[A(0)] \rho(0)\right\rbrace,$$ from which we identify $A(t) = \ee^{\LL^\dagger t}[A(0)]$ as the operator $A$ in the Heisenberg picture, which obviously satisfies the differential equation $$ \frac{\dd A}{\dd t} = \LL^\dagger[A].$$ All that remains is to check that indeed $$ \LL^\dagger[A] = \ii [H,A] + \sum_k \left ( L^\dagger_k A L_k - \frac{1}{2} \lbrace L_k^\dagger L_k ,A\rbrace \right),$$ which can be shown using the definition of $\LL^\dagger$ and the cyclicity of the trace.
Refering to the motivation given by @markmitchison, The issue with the derivation motivated above is that, if we try to compute the expectation values of some powers of time evolved operator $\hat{O}(t)$, it wont agree in general with the correct expectation value. For example if we first solve for $\hat{O}(t)$ and then we try to evaluate $\langle\hat{O}(t)\hat{O}(t)\rangle$ or something it wont be correct. I dont know exactly what is the reason for this, but there might be something to do with the fact that the open system dynamics of Hisenberg operators should also include noise terms.
Let me give you one specific example where I have encountered this. Lets take Hamiltonian
\begin{align} \hat{H} = \Delta \sum_{n=-\infty}^{\infty} \left( |n\rangle \langle n+1| + h.c \right), \label{eq:TightBinding} \end{align}
Let us define operators as,
\begin{align*} \hat{X}=d\hat{N}=d\sum_{n=-\infty}^{\infty}n|n\rangle \langle n|, \hspace{0.2cm} \hat{K}=\sum\limits_{n=-\infty}^{\infty}|n\rangle \langle n+1|, \hspace{0.2cm} \hat{K}^{\dagger}=\sum_{n=-\infty}^{\infty}|n+1\rangle \langle n|, \end{align*}
These operators satisfy,
\begin{align*} [\hat{K},\hat{N}]=\hat{K}, \hspace{0.5cm} [\hat{K}^{\dagger},\hat{N}]=-\hat{K}^{\dagger}, \hspace{0.5cm} [\hat{K},\hat{K}^{\dagger}]=0. \end{align*}
In the form of these operators, the Hamiltonian becomes,
\begin{align} \hat{H}= \Delta (\hat{K}+\hat{K}^{\dagger}) \label{eq:TightBinding2}, \end{align}
Coming to the continuous measurement part, the non-selective master equation for the dynamics of the system is,
\begin{align} \dot{\hat{\rho}} = -\frac{i}{\hbar}[\hat{H},\hat{\rho}] - \frac{\Gamma}{2}[\hat{X},[\hat{X},\hat{\rho}]] \label{NSmasterequation}, \end{align}
Where $\Gamma$ is the parameter that controls the strength of the measurement. We will be interested in the dynamics of the mean position $\langle\hat{X}\rangle$ and the variance of the position $\sigma_x=\sqrt{\langle\hat{X}^2\rangle-\langle\hat{X}\rangle^2}$. We can write down the equivalent adjoint master equation for any explicitly time-independent system operator $\hat{O}$ as,
\begin{align} \dot{\hat{O}} = -\frac{i}{\hbar}[\hat{O},\hat{H}] - \frac{\Gamma}{2}[\hat{X},[\hat{X},\hat{O}]] \label{NSadjointmasterequation} \end{align}
Let us write down the equation of motion for $\hat{X}$. We have,
\begin{align} \dot{\hat{X}} &= -\frac{i}{\hbar}[\hat{X},\hat{H}] - \frac{\Gamma}{2}[\hat{X},[\hat{X},\hat{X}]] \nonumber\\ &= -\frac{id\Delta}{\hbar}[\hat{N},(\hat{K}+\hat{K}^{\dagger})]+0\nonumber\\ &= -\frac{id\Delta}{\hbar} (\hat{K}^{\dagger}-\hat{K}). \label{xopequation} \end{align}
Now the time evolution of the operator $\hat{K}$ is,
\begin{align} \dot{\hat{K}} &= -\frac{i}{\hbar}[\hat{K},\hat{H}] - \frac{\Gamma}{2}[\hat{X},[\hat{X},\hat{K}]] \nonumber\\ &=0-\frac{\Gamma d^2}{2}[\hat{N},[\hat{N},\hat{K}]] \nonumber\\ &=-\frac{\Gamma d^2}{2}\hat{K} \nonumber \end{align}
From the above equation we can see that $\hat{K}^{\dagger}(t) - \hat{K}(t) = e^{-\frac{\Gamma d^2}{2}t}(\hat{K}^{\dagger}(0)-\hat{K}(0))$. Using this solution we get,
\begin{align} \dot{\hat{X}} &= -\frac{id\Delta}{\hbar} e^{-\frac{\Gamma d^2}{2}t}(\hat{K}^{\dagger}(0)-\hat{K}(0))\nonumber\\ \implies \hat{X}_t &= \hat{X}_0 + \frac{2i\Delta}{\hbar\Gamma d}\left(\hat{K}^{\dagger}_0-\hat{K}_0\right)\left(e^{-\frac{\Gamma d^2}{2}t}-1\right) \label{xopequation2} \end{align}
From the above equation we get the time evolution of $\langle\hat{X}\rangle_t$ as,
\begin{align} \langle\hat{X}\rangle_t &= \langle\hat{X}\rangle_0 + \frac{2i\Delta}{\hbar\Gamma d}\left(\langle\hat{K}\rangle^{\dagger}_0-\langle\hat{K}\rangle_0\right)\left(e^{-\frac{\Gamma d^2}{2}t}-1\right) \label{xopmeanequation} \end{align}
Now let us look at the time evolution of the $\langle X^2\rangle_t$ of the initially localized wavefunction.
\begin{align} \hat{X}_t^2 = \hat{X}_0^2-\left(\frac{4\Delta^2}{\hbar^2d^2\Gamma^2}\right)\left(e^{-\frac{\Gamma d^2}{2}t}-1\right)^2(\hat{K}_0^{\dagger}-\hat{K}_0)^2 + \left(\frac{2i\Delta}{\hbar\Gamma d}\right)\left(e^{-\frac{\Gamma d^2}{2}t}-1\right)\{\hat{X}_0,(\hat{K}_0^{\dagger}-\hat{K}_0)\} \label{xop2equations} \end{align}
For the expectation values we get,
\begin{align} \langle\hat{X}^2\rangle_t = \langle\hat{X}^2\rangle_0-\left(\frac{4\Delta^2}{\hbar^2d^2\Gamma^2}\right)\left(e^{-\frac{\Gamma d^2}{2}t}-1\right)^2\langle(\hat{K}^{\dagger}-\hat{K})^2\rangle_0 + \left(\frac{2i\Delta}{\hbar\Gamma d}\right)\left(e^{-\frac{\Gamma d^2}{2}t}-1\right)\langle\{\hat{X},(\hat{K}^{\dagger}-\hat{K})\}\rangle_0 \label{xop2meanequations} \end{align}
For the initial condition $|0\rangle$ we have, $\langle\hat{X}\rangle, \langle(\hat{K}^{\dagger}-\hat{K})\}\rangle_0=0$, $\langle\hat{X}^2\rangle_0=0$ and $\langle(\hat{K}^{\dagger}-\hat{K})^2\rangle_0=-2$ and we get,
\begin{align} \langle\hat{X}^2\rangle_t = \left(\frac{8\Delta^2}{\hbar^2d^2\Gamma^2}\right)\left(e^{-\frac{\Gamma d^2}{2}t}-1\right)^2 \label{xop2meanequations2} \end{align}
It turn out that this expression is incorrct. The correct experssion can be derived by writing down the closed form equation of motion for the moments we have,
\begin{align} \frac{d}{dt}\begin{pmatrix} \langle \hat{N}^2\rangle\\ \langle \{\hat{N},\hat{K}\}^{\dagger} \rangle -\langle \{\hat{N},\hat{K}\}\rangle\\ \langle \hat{K}^2 - \hat{K}\hat{K}^{\dagger}\rangle\\ \langle \hat{K}^2 \rangle \end{pmatrix} &= \begin{pmatrix} 0 & -i\Delta & 0 & 0\\ 0 -\frac{\Gamma}{2} & -4i\Delta & 0\\ 0 & 0 & 0 & -\Gamma\\ 0 & 0 & 0 & -2\Gamma \end{pmatrix} \begin{pmatrix} \langle \hat{N}^2\rangle\\ \langle \{\hat{N},\hat{K}\}^{\dagger} \rangle -\langle \{\hat{N},\hat{K}\}\rangle\\ \langle \hat{K}^2 - \hat{K}\hat{K}^{\dagger}\rangle\\ \langle \hat{K}^2 \rangle \end{pmatrix} \end{align}
With the initial condition, $ \langle \hat{N}^2\rangle_0 = \langle \{\hat{N},\hat{K}\}^{\dagger} \rangle -\langle \{\hat{N},\hat{K}\}\rangle = \langle \hat{K}^2 \rangle = 0$ and $ \langle \hat{K}^2 - \hat{K}\hat{K}^{\dagger}\rangle = 1$ we get,
\begin{align} \langle \hat{N}^2\rangle_t = \frac{8\Delta^2}{\Gamma^2}\left[\Gamma t - 2\left(1 - e^{-\frac{1}{2}\Gamma t}\right) \right] \label{xop2meanequations3} \end{align}
It was a long time ago that I did this calculations and I still do not know the exact reason as to why the first approach gives incorrect expressions.
