When light interacts with matter, it is (most often) the electric field that is absorbed. So what happens with the magnetic field when the electric field interacts with, say, an electron? Assuming that the electron absorbs the light and oscillates at the frequency as the incident wave, and then re-emits this light in all directions, the magnetic wave has to "follow" the electric component in order for light to be re-emitted from the electron?
Yoda
  • 639
In an electromagnetic wave the electric and magnetic fields are always intrinsically linked. In a plane transverse electromagnetic wave the amplitude of the transverse magnetic field H (which oscillates in a plane normal to that of the electric field) is given by H=E/Z, where Z is a constant called wave impedance, which is about 377 Ohms in free space. When light interacts with matter via the electric field both the electric and the magnetic field are reduced simultaneously.
freecharly
  • 18,177
In the classical scenario you pose, no work is done by the electromagnetic field - the dot product of the E-field and current is zero. Thonson scattering is an elastic interaction.
The scattered waves have exactly the same relationships between the E- and B-field as any other vacuum wave solution of Maxwell's equations.
Things change if the wave interacts dissipatively - for example at an interface with a conductor. Here there are Ohmic losses.
In vacuum, an EM wave has equal energy densities in the electric and magnetic field and the E- and B-fields oscillate in phase. When you use the appropriate boundary conditions with Maxwell's equations, you find that the ratio of E- to B-field is dramatically reduced in the conductor. Most of the energy density is now in the magnetic component and the E- and B-fields are roughly 45 degrees out of phase.
ProfRob
  • 141,325
