15
In many pop physics books I have read that an electron has no internal structure.
How do we know that and how can we rigorously prove that it has no such structure at all?
Steeven
  • 53,191
Xasel
  • 373
We study it using deep inelastic scattering. It was this type of experiment that first revealed the proton had an internal structure, and if the electron has an internal structure it will be this type of experiment that reveals it.
No experiment has yet discovered evidence for an internal structure in the electron, however that doesn't prove the electron has no internal structure. It proves only that any structure is too small scale for us to probe at the energies available. So contrary to what you say in your question, we haven't rigorously proved that the electron has no structure.
There is a long standing idea that the apparently fundamental particles like electrons and quarks might be bound states of fundamental particles called preons, though I must emphasise that there is no experimental evidence for this idea and there is some theoretical evidence against the idea.
We know the electron size must be less than about $10^{-18}$m because we've already probed that length scale in collider experiments. That means any preons have to be confined within $10^{-18}$m and the uncertainty principle implies a correspondingly large uncertainty in momentum. This would suggest the preon bound state has a high energy and therefore a high mass - certainly higher than the electron mass. There are ways around this so it isn't proof that the electron isn't a bound state. However the ways to avoid an excessively high mass are a bit contrived and will get more so as we probe to smaller and smaller length scales.
John Rennie
  • 367,598
You can't "prove" the electron has or has not internal structure. All you can do are collision experiments at the energies available to you. Along these lines the proposed ILC (International Linear Collider) - if build - will provide an unprecedented new look at the electron (and positron).
Ken Abbott
  • 355
The electron has a magnetic dipole moment and an intrinsic spin. Both phenomenon need an extend and a structure and hence the electron has to have an internal structure.
That until know we haven't found this structure has to do with our capabilities to build the right instrument.
HolgerFiedler
  • 10,980
