The operative question here is: did your course cover multi-variate calculus, or just the calculus of one variable? If not, then you're dealing with something new. (Or ... were. This is 7 years past, now, at the time of writing.)
All differential relations are exact for univariate calculus. That means, if you write:
$$dy = A dx$$
then you can express $y = f(x)$, for some function $f$ of $x$, such that $f'(x) = A$. So, when you see the term "inexact differential" that means you have multiple variables involved and you're dealing with multi-variate calculus.
If $z = f(x,y)$ is a function of two variables $x$ and $y$, then its differential $dz$ is expressed in terms of the differentials $dx$ and $dy$ as:
$$dz = f_x(x,y) dx + f_y(x,y) dy,$$
with the differential coefficients written as:
$$\frac{∂z}{∂x} = f_x(x,y), \quad \frac{∂z}{∂y} = f_y(x,y).$$
Thus, for instance, if $z = x^2y + 2y$, then the differential relation can be written as
$$dz = (2xdx)y + x^2 dy + 2 dy = (2xy) dx + (x^2 + 2) dy,$$
and the corresponding differential coefficients are:
$$\frac{∂z}{∂x} = 2xy, \quad \frac{∂z}{∂y} = x^2 + 2.$$
These are the partial derivatives of $z$ with respect to $x$ and $y$.
A differential form $A dx + B dy$ is exact if there is function $f(x,y)$, such that $A = f_x(x,y)$ and $B = f_y(x,y)$. The hallmark condition for that arises from the fact the order of mixed partial derivatives commute. For instance
$$\frac{∂}{∂y}\frac{∂z}{∂x} = \frac{∂}{∂y}(2xy) = 2x,\quad \frac{∂}{∂x}\frac{∂z}{∂y} = \frac{∂}{∂x}(x^2 + 2) = 2x.$$
Thus
$$\frac{∂}{∂y}\frac{∂z}{∂x} = \frac{∂}{∂x}\frac{∂z}{∂y}.$$
So, a test for the exactness of $A dx + B dy$ is that
$$\frac{∂A}{∂y} = \frac{∂B}{∂x}.$$
The test and condition can be directly and cleanly stated using Grassmann algebra with differential forms. The formalism of differential forms and its associated algebra are best explained by illustrating its use here:
$$\begin{align}
d(A dx)
&= dA∧dx + A d(dx)\\
&= \left(\frac{∂A}{∂x} dx + \frac{∂A}{∂y} dy\right)∧dx + A d^2x\\
&= \frac{∂A}{∂x} dx∧dx + \frac{∂A}{∂y} dy∧dx & \text{since }d^2x = 0,\\
&= -\frac{∂A}{∂y}dx∧dy & \text{since }\left\{\begin{matrix}dx∧dx = 0,\\dy∧dx = -dx∧dy\end{matrix}\right\};\\
d(B dy)
&= \left(\frac{∂B}{∂x} dx + \frac{∂B}{∂y} dy\right)∧dy + B d^2y\\
&= \frac{∂B}{∂x}dx∧dy;\\
d(A dx + B dy)
&= d(A dx) + d(B dy)\\
&= \left(\frac{∂B}{∂x} - \frac{∂A}{∂y}\right) dx∧dy.
\end{align}$$
A differential form $ω = A dx + B dy$ is closed if $dω = 0$. It is exact if $ω = dz$, for some $z = f(x,y)$, and the process of finding the function $f(x,y)$ that produces the differential equation - as in the univariate case - is called integrating the differential equation and the differential form $ω$. All exact differential forms are closed; so checking closure is a test for exactness. With the right extra assumptions, it's also a watertight test for exactness.
A central hypothesis of thermodynamics is that the inexact differential form $δQ$, as you denoted it, can be made exact with an integrating factor:
$$dS = \frac{δQ}{T}.$$
The extra factor $T$ is identified as the temperature, and the variable $S$ that it integrates to, when the factor is included, is the entropy.
An example of an inexact differential form that can be made exact with an integrating factor is
$$x dy - y dx.$$
It becomes exact with
$$\frac{x dy - y dx}{x^2}.$$
You can verify this by showing that it is closed, i.e. that:
$$\frac{∂}{∂x}\frac{x}{x^2} = \frac{∂}{∂x}\frac{1}{x} = -\frac{1}{x^2} = \frac{∂}{∂y}\frac{-y}{x^2}.$$
Its integration can be made transparent by rewriting it as:
$$\frac{x dy - y dx}{x^2} = \frac{1}{x}dy + \left(\frac{-dx}{x^2}\right)y = \frac{1}{x}dy + d\left(\frac{1}{x}\right)y = d\left(\frac{y}{x}\right).$$
So, it is exact -- except in the vicinity of $x = 0$. So, in any region of the $(x,y)$-plane that stays away from the $y$ axis - which is where $x = 0$ - the differential form is exact.
