Yes, but one first has to generalize the classical 2-point Brachistochrone problem $A \to B$ where the initial speed $v_A$ traditionally is zero, to the case where the initial speed $v_A$ may be non-zero but fixed. The solution to this initial speed Brachistochrone problem (assuming no friction) is still a cycloid.
Now consider the 3-points Brachistochrone problem $A \to B\to C$ with initial speed $v_A$. The speed $v_B$ is given by energy conservation alone. Thus the two segments $A \to B$ and $B \to C$ are completely decoupled$^1$, and they can be optimized as two independent 2-point Brachistochrone problems with initial speeds $v_A$ and $v_B$, respectively, leading to two corresponding cycloids $A \to B$ and $B \to C$.
$^1$Here I'm considering the idealized Brachistochrone problem where solution curves are allowed to be only piecewise smooth. Instantaneous change of velocity (with no change in speed) is provided by an idealized (infinitely big) normal force, which does no work.
