11
I'm looking for texts about topics in string theory that are "advanced" in the sense that they go beyond perturbative string theory. Specifically I'm interested in
  1. String field theory (including superstrings and closed strings)
  2. D-branes and other branes (like the NS5)
  3. Dualities
  4. M-theory
  5. AdS/CFT
  6. Matrix theory
  7. F-theory
  8. Topological string theory
  9. Little string theory
I'm not interested (at the moment) at string phenomenology and cosmology
I prefer texts which are (in this order of importance)
  • Top-down i.e. would give the conceptual reason for something first instead of presenting it as an ad-hoc construction, even if the conceptual reason is complicated
  • Use the most appropriate mathematical language / abstractions (I'm not afraid of highbrow mathematics)
  • Up to date with recent developments
Among normal books, Becker-Becker-Schwarz probably matches your summary most closely. However, you may want to look at a list of string theory books:
http://motls.blogspot.com/2006/11/string-theory-textbooks.html
Don't miss the "resource letter" linked at the bottom which is good for more specialized issues such as string field theory. An OK review of string field theory could be this one
http://arxiv.org/abs/hep-th/0102085
but it was written before many recent advances, such as Martin Schnabl's analytic solution for the closed string vacuum and its followups.
I must correct your comment that you're interested in "nonperturbative" issues such as string field theory. It's been established that despite some expectations, string field theory is just another way to formulate perturbative string theory. It is not useful to learn anything about the strong coupling, not even in principle. And it becomes a mess in the superstring case. There are no functional string field theory descriptions with closed string physical states seen in the physical spectrum at all; it has various reasons. For example, a description that is ultimately "a form of field theory" can never produce the modular invariance $SL(2,{\mathbb Z})$ (needed to get rid of the multiple counting of the 1-loop diagrams). String theory is extremely close to a field theory but it is not really a field theory in spacetime in this strict sense and this fact becomes much more apparent for closed strings (which include gravity at low energies) than in the case of open strings (that may be largely emulated by point-particle fields – related to Yang-Mills being in the low-energy limit of open strings).
For a review of topological string theory, see e.g.
http://motls.blogspot.com/2004/10/topological-string-theory.html
Quite generally, when you study the literature (or reviews), you may find out that your pre-existing expectations about the amount of knowledge people have about various subtopics i.e. about their "relative importance in the current picture" is different than you may expect a priori. Without knowing the actual content, one can't sensibly "allocate" the number of pages to various subtopics as you did so.
Luboš Motl
  • 182,599
You can consult stringwiki.org.
