I asked a similar question but it was closed with no valid reason, this question asks a surely legit question of what happens when a charge moves at $c-\epsilon$.
Consider an electron that actually spins at c-1 planck's L. I imagine that even such a little difference means a lot, but even so, can you tell me what happens? I read some articles that justify all electrons properties just by it spinnin at c: they mention auto induction, magnetic pressure (?) that compensates charge repulsion, resonant frequency of LC circuit etc...
[Note: do you know why the actual spinning of the electron has been discarded and a meaningless 'intrinsic' property has been accepted? I know little of the mentioned processes an formulas, but one thing strikes me as plain and obvious, if the charge spins at near c the magnetic attraction almos compensate the repulsion, and the residual force explains the perfect spherical shape. Also, using the classical values, the magnitude of the spin is short by a factor smaller than 10 and a spin at 0.995 c already produces an angular momentum 10 times greater.]
Can you please focus on (auto-) induction if it exists, or on what could cause a boost of the original energy?
edit
since it has been considered a duplicate: isn't there a great difference between speed at near c or at c, in the consequences a charge would experience when it can be affected byits own electrostatic force?
