127
The purpose of this question is to ask about the role of mathematical rigor in physics. In order to formulate a question that can be answered, and not just discussed, I divided this large issue into five specific questions.
Update February, 12, 2018: Since the question was put yesterday on hold as too board, I ask future to refer only to questions one and two listed below. I will ask a separate questions on item 3 and 4. Any information on question 5 can be added as a remark.
  1. What are the most important and the oldest insights (notions, results) from physics that are still lacking rigorous mathematical formulation/proofs.
  2. The endeavor of rigorous mathematical explanations, formulations, and proofs for notions and results from physics is mainly taken by mathematicians. What are examples that this endeavor was beneficial to physics itself.
  1. What are examples that insisting on rigour delayed progress in physics.
  2. What are examples that solid mathematical understanding of certain issues from physics came from further developments in physics itself. (In particular, I am interested in cases where mathematical rigorous understanding of issues from classical mechanics required quantum mechanics, and also in cases where progress in physics was crucial to rigorous mathematical solutions of questions in mathematics not originated in physics.)
  3. The role of rigor is intensely discussed in popular books and blogs. Please supply references (or better annotated references) to academic studies of the role of mathematical rigour in modern physics.
(Of course, I will be also thankful to answers which elaborate on a single item related to a single question out of these five questions. See update)
Related Math Overflow questions:
Gil Kalai
  • 2,113
Rigorous arguments are very similar to computer programming--- you need to write a proof which can (in principle) ultimately be carried out in a formal system. This is not easy, and requires defining many data-structures (definitions), and writing many subroutines (lemmas), which you use again and again. Then you prove many results along the way, only some of which are of general usefulness.
This activity is extremely illuminating, but it is time consuming, and tedious, and requires a great deal of time and care. Rigorous arguments also introduce a lot of pedantic distinctions which are extremely important for the mathematics, but not so important in the cases one deals with in physics.
In physics, you never have enough time, and we must always have a only just precise enough understanding of the mathematics that can be transmitted maximally quickly to the next generation. Often this means that you forsake full rigor, and introduce notational short-cuts and imprecise terminology that makes turning the argument rigorous difficult.
Some of the arguments in physics though are pure magic. For me, the replica trick is the best example. If this ever gets a rigorous version, I will be flabbergasted.
1) What are the most important and the oldest insights (notions, results) from physics that are still lacking rigorous mathematical formulation/proofs.
Here are old problems which could benefit from rigorous analysis:
  • Mandelstam's double-dispersion relations: The scattering amplitude for 2 particle to 2 particle scattering can be analytically expanded as an integral over the imaginary discontinuity $\rho(s)$ in the s parameter, and then this discontinuity $\rho(s)$ can be written as an integral over the t parameter, giving a double-discontinuity $\rho(s,t)$ If you go the other way, expand the discontinuity in t first then in s, you get the same function. Why is that? It was argued from perturbation theory by Mandelstam, and there was some work in the 1960s and early 1970s, but it was never solved as far as I know.
  • The oldest, dating back centuries: Is the (Newtonian, comet and asteroid free) solar system stable for all time? This is a famous one. Rigorous bounds on where integrability fails will help. The KAM theorem might be the best answer possible, but it doesn't answer the question really, since you don't know whether the planetary perturbations are big enough to lead to instability for 8 planets some big moons, plus sun.
  • continuum statistical mechanics: What is a thermodynamic ensemble for a continum field? What is the continuum limit of a statistical distribution? What are the continuous statistical field theories here?
  • What are the generic topological solitonic solutions to classical nonlinear field equations? Given a classical equation, how do you find the possible topological solitons? Can they all be generated continuously from given initial data? For a specific example, consider the solar-plasma--- are there localized magneto-hydrodynamic solitons?
There are a bazillion problems here, but my imagination fails.
2) The endeavor of rigorous mathematical explanations, formulations, and proofs for notions and results from physics is mainly taken by mathematicians. What are examples that this endeavor was beneficial to physics itself.
There are a few examples, but I think they are rare:
  • Penrose's rigorous proof of the existence of singularities in a closed trapped surface is the canonical example: it was a rigorous argument, derived from Riemannian geometry ideas, and it was extremely important for clarifying what's going on in black holes.
  • Quasi-periodic tilings, also associated with Penrose, first arose in Hao and Wang's work in pure logic, where they were able to demonstrate that an appropriate tiling with complicated matching edges could do full computation. The number of tiles were reduced until Penrose gave only 2, and finally physicists discovered quasicrystals. This is spectacular, because here you start in the most esoteric non-physics part of pure mathematics, and you end up at the most hands-on of experimental systems.
  • Kac-Moody algebras: These came up in half-mathematics, half early string theory. The results became physical in the 1980s when people started getting interested in group manifold models.
  • The ADE classificiation from Lie group theory (and all of Lie group theory) in mathematics is essential in modern physics. Looking back further, Gell-Mann got SU(3) quark symmetry by generalizing isospin in pure mathematics.
  • Obstruction theory was essential in understanding how to formulate 3d topological field theories (this was the subject of a recent very interesting question), which have application in the fractional quantum hall effect. This is very abstract mathematics connected to laboratory physics, but only certain simpler parts of the general mathematical machinery are used.
3) What are examples that insisting on rigour delayed progress in physics.
This has happened several times, unfortunately.
  • Statistical mechanics: The lack of rigorous proof of Boltzmann ergodicity delayed the acceptance of the idea of statistical equilibrium. The rigorous arguments were faulty--- for example, it is easy to prove that there are no phase transitions in finite volume (since the Boltzmann distribution is analytic), so this was considered a strike against Boltzmann theory, since we see phase transitions. You could also prove all sorts of nonsense about mixing entropy (which was fixed by correctly dealing with classical indistinguishability). Since there was no proof that fields would come to thermal equilibrium, some people believed that blackbody light was not thermal. This delayed acceptance of Planck's theory, and Einstein's. Statistical mechanics was not fully accepted until Onsager's Ising model solution in 1941.
  • Path integrals: This is the most notorious example. These were accepted by some physicists immediately in the 1950s, although =the formalism wasn't at all close to complete until Candlin formulated Grassman variables in 1956. Past this point, they could have become standard, but they didn't. The formalism had a bad reputation for giving wrong results, mostly because people were uncomfortable with the lack of rigor, so that they couldn't trust the method. I heard a notable physicist complain in the 1990s that the phase-space path integral (with p and q) couldn't possibly be correct because p and q don't commute, and in the path integral they do because they are classical numbers (no, actually, they don't--- their value in an insertion depends discontinuously on their time order in the proper way). It wasn't until the early 1970s that physicists became completely comfortable with the method, and it took a lot of selling to overcome the resistance.
  • Quantum field theory construction: The rigorous methods of the 1960s built up a toolbox of complicated distributional methods and perturbation series resummation which turns out to be the least useful way of looking at the thing. It's now C* algebras and operator valued distributions. The correct path is through the path integral the Wilsonian way, and this is closer to the original point of view of Feynman and Schwinger. But a school of rigorous physicists in the 1960s erected large barriers to entry in field theory work, and progress in field theory was halted for a decade, until rigor was thrown out again in the 1970s. But a proper rigorous formulation of quantum fields is still missing.
In addition to this, there are countless no-go theorems that delayed the discovery of interesting things:
  • Time cannot be an operator (Pauli): this delayed the emergence of the path integral particle formulation due to Feynman and Schwinger. Here, the time variable on the particle-path is path-integrated just like anything else.
  • Von-Neumann's proof of no-hidden variables: This has a modern descendent in the Kochen Sprecher theorem about entangled sets of qubits. This delayed the Bohm theory, which faced massive resistance at first.
  • No charges which transform nontrivially under the Lorentz group(Coleman-Mandula): This theorem had both positive and negative implications. It killed SU(6) theories (good), but it made people miss supersymmetry (bad).
  • Quasicrystal order is impossible: This "no go" theorem is the standard proof that periodic order (the general definition of crystals) is restricted to the standard space-groups. This made quasicrystals bunk. The assumption that is violated is the assumption of strict periodicity.
  • No supergravity compactifications with chiral fermions (Witten): this theorem assumed manifold compactification, and missed orbifolds of 11d SUGRA, which give rise to the heterotic strings (also Witten, with Horava, so Witten solved the problem).
4) What are examples that solid mathematical understanding of certain issues from physics came from further developements in physics itself. (In particular, I am interested in cases where mathematical rigorous understanding of issues from classical mechanics required quantum mechenics, and also in cases where progress in physics was crucial to rigorous mathematical solutions of questions in mathematics not originated in physics.)
There are several examples here:
  • Understanding the adiabatic theorem in classical mechanics (that the action is an adiabatic invariant) came from quantum mechanics, since it was clear that it was the action that needed to be quantized, and this wouldn't make sense without it being adiabatic invariant. I am not sure who proved the adiabatic theorem, but this is exactly what you were asking for--- an insightful classical theorem that came from quantum mechanics (although some decades before modern quantum mechanics)
  • The understanding of quantum anomalies came directly from a physical observation (the high rate of neutral pion decay to two photons). Clarifying how this happens through Feynman diagrams, even though a naive argument says it is forbidden led to complete understanding of all anomalous terms in terms of topology. This in turn led to the development of Chern-Simons theory, and the connection with Knot polynomials, discovered by Witten, and earning him a Fields medal.
  • Distribution theory originated in Dirac's work to try to give a good foundation for quantum mechanics. The distributional nature of quantum fields was understood by Bohr and Rosenfeld in the 1930s, and the mathematics theory was essentially taken from physics into mathematics. Dirac already defined distributions using test functions, although I don't think he was pedantic about the test-function space properties.
5) The role of rigor is intensly discussed in popular books and blogs. Please supply references (or better annotated references) to academic studies of the role of mathematical rigour in modern physics.
I can't do this, because I don't know any. But for what it's worth, I think it's a bad idea to try to do too much rigor in physics (or even in some parts of mathematics). The basic reason is that rigorous formulations have to be completely standardized in order for the proofs of different authors to fit-together without seams, and this is only possible in very long hindsight, when the best definitions become apparent. In the present, we're always muddling through fog. So there is always a period where different people have slightly different definitions of what they mean, and the proofs don't quite work, and mistakes can happen. This isn't so terrible, so long as the methods are insightful.
The real problem is the massive barrier to entry presented by rigorous definitions. The actual arguments are always much less daunting than the superficial impression you get from reading the proof, because most of the proof is setting up machinery to make the main idea go through. Emphasizing the rigor can put undue emphasis on the machinery rather than the idea.
In physics, you are trying to describe what a natural system is doing, and there is no time to waste in studying sociology. So you can't learn all the machinery the mathematicians standardize on at any one time, you just learn the ideas. The ideas are sufficient for getting on, but they aren't sufficient to convince mathematicians you know what you're talking about (since you have a hard time following the conventions). This is improved by the internet, since the barriers to entry have fallen down dramatically, and there might be a way to merge rigorous and nonrigorous thinking today in ways that were not possible in earlier times.
69
Rigor is clarity of concepts and precision of arguments. Therefore in the end there is no question that we want rigor.
To get there we need freedom for speculation, first, but for good speculation we need...
...solid ground, which is the only ground that serves as a good jumping-off point for further speculation.
in the words of our review, which is all about this issue.
Sometimes physicists behave as if rigor is all about replacing an obvious but non-precise argument with a tedious and boring proof. But more often than not rigor is about identifying the precise and clear definitions such that the obvious argument becomes also undoubtly correct.
There are many historical examples.
For instance the simple notion of differential forms and exterior derivatives. It's not a big deal in the end, but when they were introduced into physics they not only provided rigor for a multitude of vague arguments about infinitesimal variation and extended quantity. Maybe more importantly, they clarified structure. Maxwell still filled two pages with the equations of electromagnetism at a time when even the concepts of linear algebra were an arcane mystery. Today we say just $d \star d A = j_{el}$ and see much further, for instance derive the charge quantization law rigorously with child's ease. The clear and precise concept is what does this for us.
And while probably engineers could (and maybe do?) work using Maxwell's original concepts, the theoreticians would have been stuck. One can't see the subtleties of self-dual higher gauge theory, for instance, without the rigorous concept of de Rham theory.
There are many more examples like this. Here is another one: rational CFT was "fully understood" and declared solved at a non-rigorous level for a long time. When the rigorous FRS-classification of full rational CFT was established, it not onyl turned out that some of the supposed rational CFT construction in the literature did not actually exist, while other existed that had been missed, more importantly was: suddenly it was very clear why and which of these examples exist. Based on the solid ground of this new rigor, it is now much easier to base new non-rigorous arguments that go much further than one could do before. For instance about the behaviour of rational CFT in holography.
Rigor is about clarity and precision, which is needed for seeing further. As Ellis Cooper just said elsewhere:
Rigor cleans the window through which intuition shines.
Urs Schreiber
  • 14,227
34
I still think that it's not the right place for this type of questions. Nevertheless, the topic itself is interesting, and I'll also have a shot at it. Since I'm neither a philosopher of science, nor an historian (and there are probably very few such people on this site, one of the reasons this question might not be suitable), I'll focus on my own restricted field, statistical physics.
  1. There are many. For example, a satisfactory rigorous derivation of Boltzmann equation, the best result to this day remaining the celebrated theorem of Lanford proved in the late 1970s. In equilibrium statistical mechanics, one of the major open problems is the proof that the two-dimensional $O(N)$ models have exponentially decaying correlations at all temperatures when $N>2$ (there is supposedly a close relationship between such models and four-dimensional gauge models, and this problem might shed light on the issue of asymptotic freedom in QCD, see this paper for a critical discussion of these issues). Of course, there are many others, such as trying to understand why naive real-space renormalization (say, decimation) of lattice spin systems provides reasonably accurate results (even though such transformations are known to be generally ill-defined mathematically); but it seems to me that it's unlikely to happen, which does not mean that the philosophy of the renormalization group cannot find uses in mathematical physics (it already has led to several profound results).
  2. Well, one major example was Onsager's rigorous computation of the free energy of the 2d Ising model, which showed that all approximation schemes used by physicists at that time were giving completely wrong predictions. Rigorous results can also lead to (i) new approaches to old problems (this is the case recently with SLE), (ii) new results that were not known to physicists (this is the case with, e.g., the results of Johansson and others on growth models), (iii) a much better understanding of some complicated phenomena (e.g., the equilibrium properties of fixed magnetization Ising models), (iv) settling controversies in the physics literature (a famous example was the problem of determining the lower critical dimension of the random-field Ising model, which was hotly debated in the 1980s, and was rigorously settled by Bricmont and Kupiainen).
  3. None that I know of. Although, one might say that the "paradoxes" raised against Boltzmann's theory by Zermelo and Loschmidt were both of mathematical nature (and thus criticized the apparent lack of of rigour of Boltzmann's approach), and did delay the acceptance of his ideas.
  4. Not sure about this point. Certainly the numerous conjectures originating from physics, in particular striking predictions, provide both motivation, and sometimes some degree of insight to the mathematicians... But I am not sure that's what you're asking for.
  5. There are many papers discussing such issues, e.g.:
and references therein.
Glorfindel
  • 1,424
  • 17
Yvan Velenik
  • 11,352
22
I can by no means claim to give a full answer on this question, but perhaps a partial answer is better than no answer at all.
As regards (1) perhaps the most famous example is the Navier-Stokes equation. We know it produces extremely good results for modeling fluid flow, but we can't even show that there always exists a solution. Indeed, there is a Clay prize going for proving the existence of smooth solutions on $\mathbb{R}^3$ (problem statement here).
An example of (2) is that the study of topological quantum field theory has been motivated at least in part by mathematics.
As regards (3) I don't really think this has ever happened. However, by this, I do not mean that demanding rigor would not prevent or slow the progression of physics, but rather that it seems extremely hard to find an example of a case where a relatively large community has not simply ignored any such demand. Certainly it is true that mathematically rigorous formulations often follow far behind the current state of the art in physics, but there is nothing unexpected about this.
I do not currently have any good answers as regards the remainder of your question.
There is a relatively interesting essay on this (C. Vafa - On the future of mathematics/physics interaction) in Mathematics: Frontiers and Perspectives, which also mentions the TQFT example.
