Short electrostatics question. Given that a dipole moment of a charge distribution is defined as $$P = \int r' \rho(r')d \tau '$$ where $r'$ is the position vector of the source charge, and $\rho$ is the charge density. Why does it follow that if we displace the origin by an amount $\vec{a}$ then the new dipole moment $\bar{P}$ is $$\bar{P} = \int \bar{r}' \rho(r')d \tau ' = \int (r'-\vec{a})\rho(r')d \tau'$$ rather than $$\bar{P} = \int \bar{r}' \rho(\bar{r}')d \tau '?$$
I might be missing something simple? Give me a hint if possible, thanks.
Alex
  • 1,063
  • 17
  • 42
The dipole moment of a continuos charge distribution is dependent (unless your total charge is 0) by the pole you choose. If we set our pole equal to the origin of our system then we have: $$\vec{p}=\int_V \rho (\vec{r}')\vec{r}' d\tau$$ where $\vec{r}'$ is the vector position from your origin to the point you consider during integration(if you have a discrete charge distribution, then $\vec{r_i}'$ is the position of the charge $q_i$ with respect to the origin, $i$ is the index of the sum that replace the integral), and remember that you are integrating upon $d\tau=dxdydz$ which is expressed with respect to the origin. Now let's say we choose another point $A=(x_A,y_A,z_A)$. Reasoning with discrete distribution we say that we are searching the contribution of the $q_i$ charge that is still at the point $P'=\vec{r_i}'$ (we didn't change the origin) to the moment but with respect to another point $A$ which is in turn in the position $\vec{r}_A$ (thus we have the term $(\vec{r_i}'-\vec{r}_A)$), but the volume upon we are integrating is the same $d\tau$ and the point $P'$ is expressed by the same $\vec{r_i}'$ because we didn't change the origin, but only the pole. It follows that the moment with respect to the point $A$ is: $$\vec{p}_A=\int_V \rho(P'=\vec{r}')(\vec{r}'-\vec{r}_A)d\tau$$ where $V$ and $d\tau=dxdydz$ are the same of before.
pier94
  • 260
The dipole moment of a charge distribution $\rho(\mathbf r)$, which is always defined as $$ \mathbf d=\int\mathbf r\rho(\mathbf r) \: \mathrm d\mathbf r $$ with respect to some coordinate origin, is independent of said coordinate origin if and only if the system is neutral. Otherwise, as you note, it transforms to a new origin $\mathbf r_0$ as $$ \mathbf d' =\int(\mathbf r-\mathbf r_0)\rho(\mathbf r) \: \mathrm d\mathbf r =\mathbf d-\mathbf r_0\int\rho(\mathbf r) \: \mathrm d\mathbf r =\mathbf d-Q\mathbf r_0 $$ for $Q$ the total charge of the system.
(This transformation law comes from the fact that in our original equation, $\mathbf r$ actually plays two roles, that of a position and that of an arrow. In this calculation of $\mathbf d'$ I'm keeping this calculation in the old reference frame, which keeps the $\rho(\mathbf r)$ intact, but I need to change the arrow to $\mathbf r-\mathbf r_0$ so that it now points from the new coordinate origin, $\mathbf r_0$, to the position $\mathbf r$.)
For a charged system, the dipole moment takes a backseat role, but it is still a useful quantity - for example, it is still the coefficient in the $1/r^2$ term of the multipole expansion for the electrostatic potential far away from the system, $$ V(\mathbf r) = \frac{Q}{r} + \frac{\mathbf d\cdot\mathbf r}{r^3}+\cdots, $$ with quadrupole terms after that. However, it is always important to keep in mind this dependence on the coordinate origin, and to clearly state this origin whenever the dipole moment is reported for a charged system.
Emilio Pisanty
  • 137,480
You are absolutely correct . In the new reference frame dipole moment will be P¯= ∫r¯′ρ(r¯′)dτ′ And in old reference frame dipole moment will be P = ∫r′ρ(r′)dτ′
But you will have to understand what this term ρ(r′)dτ′ is . Its small charge dq which is at any given point lets say point A (Mark it red in your mind) in the charge distribution. For the same charge dq at A when observed from new frame we will have to write it as ρ(r¯′)dτ′. isn't it ?
So you can see that we can use ρ(r′)dτ′ and ρ(r¯′)dτ′ interchangeably because it points to same charge dq from different reference frame.
And thus your observation P¯= ∫r¯′ρ(r¯′)dτ′ is same as P¯=∫r¯′ρ(r′)dτ′ given in books.
Hope you got my point .
dτ′ term will be same in both reference frame . Its just dxdydz
Om Aditya
