In general relativity, the energy-momentum tensor is written as
$$ T^{\mu \nu } \sim \frac{1}{\sqrt{|g|}}\frac{\delta \mathcal L}{\delta g_{\mu\nu}},$$
while in field theory it is written as
$$ T^{\mu}{}_{ \nu } = \frac{\delta \mathcal L}{\delta \partial_{\mu} \phi} \partial_{\nu} \phi - \delta^{\mu}_{\nu} \phi .$$
I am having trouble reconciling these two expressions. Also since diffeomorphisms, and hence translational invariance, are a gauge symmetry in general relativity, how can there be a non-zero conserved current for translational invariance, i.e. the energy-momentum tensor?
JamalS
  • 19,600
You are talking about a very particular example. If you minimally couple a scalar field to gravity and use the first equation you mention you get indeed the tensor you quote in the second line "the QFT one". However this is not always the case, if you couple a spinor minimally to gravity and find the energy momentum tensor it will not match the one you get by applying Noether's theorem to the Dirac lagrangian.
One can think about General Relativity as a gauge theory with a very large gauge group, the group of diffeomorphisms as you mention. These should not be considered as symmetries giving rise to conserved charges but rather as redundancies in our mathematical description of the underlying physics.
However if your spacetime has "Killing vectors" there will be conserved charges, the tyical metrics one encounters have Killing vectors that lead to energy momentum conservation. This means there is an independent observer statement of the kind $\frac{d}{dt}Q=0$. Where $Q$ is the integral over a spatial slice of the conserved component.
If you do not have Killing vectors all you can say is $\nabla_{\mu} T^{\mu\nu}=0$. This is not a conservation law, is actually an assumption not even a mathematical fact, all this formula says is that all reasonable matter that we know about satisfies this equation.
user128505
  • 36
