25
I guess I never had a proper physical intuition on, for example, the "KMS condition". I have an undergraduate student who studies calculation of Hawking temperature using the Euclidean path integral technique, and shamefully his teacher is not able to give him a simple, intuitive argument for it. What would it be?
Added on October 21:
First of all, thanks Moshe and S Huntman for answers. My question was, however, looking for more "intuitive" answer. As Moshe pointed out it may not be possible, since after all time is "imaginary" in this case. So, let me be more specific, risking my reputation.
I should first say I understand there are formal relation between QFT and statistical mechanics as in well-known review like "Fulling & Ruijsenaars". But, when you try to explain this to students with less formal knowledge, it sometimes helps if we have an explicit examples. My motivation originally comes from "Srinivasan & Padmanabhan". In there, they says tunneling probability calculation using complex path (which is essentially a calculation of semi-classical kernel of propagator) can give a temperature interpretation because
In a system with a temperature $\beta^{-1}$ the absorption and emission probabilities are related by $$P[\text{emission}] = \exp(-\beta E)P[\text{absorption}]\tag{2.22}$$
So, I was wondering whether there is a nice simple example that shows semi-classical Kernel really represents temperature. I think I probably envisioned something like two state atom in photon field in thermal equilibrium, then somehow calculate in-in Kernel from |1> to |1> with real time and somehow tie this into distribution of photon that depends on temperature. I guess what I look for was a simple example to a question by Feynman $ Hibbs (p 296) pondering about the possibility of deriving partition function of statistical mechanics from real time path integral formalism.
Lorenzo B.
  • 562
  • 16
Lots of different ways to answer, but none of them can be too intuitive since imaginary time is, well, imaginary. But here is one attempt to make the result more or less self-evident.
The basic object to calculate in quantum statistical mechanics (in thermal equilibrium, in the canonical ensemble) is the partition function (with potential insertions if you want to calculate correlation functions):
$$Z= \operatorname{Tr}(e^{-\beta H})= \sum_\psi \langle \psi(0)|e^{-\beta H}|\psi(0) \rangle$$
where $H$ is the Hamiltonian and we have a sum over any complete set of states $\psi$, written in the Schrödinger picture at some fixed time which we take to be $t=0$. In that picture the time evolution of a state is
$$|\psi(t)\rangle = e^{-i t H}|\psi(0)\rangle$$
The basic observation now is that the Boltzmann factor $e^{-\beta H}$ can be regarded as an evolution of the state $\psi$ over imaginary time period $-i \beta$. Therefore we can write:
$$Z= \sum_\psi \langle \psi(0)|\psi(-i\beta) \rangle$$
This is now the vacuum amplitude (with possible insertions) which is the sum over all states $\psi$ in some arbitrary complete basis. Except that you propagate any final states with time $ i \beta$ with respect to the initial state. In other words however you choose to calculate your vacuum amplitude (or correlation function) — a popular method is a path integral — you have to impose the condition that the initial and final states are the same up to that imaginary time shift. This is the origin of the imaginary time periodicity.
Lorenzo B.
  • 562
  • 16
The time evolution of an observable $\hat A$ in the Heisenberg picture is given as usual by $\tau_t(\hat A) := e^{i\mathcal{\hat H}t/\hbar} \hat A e^{-i\mathcal{\hat H}t/\hbar}$. The quantum Gibbs rule $\langle \hat A \rangle = \mbox{Tr}(\hat \rho \hat A)$, with $\hat \rho := Z^{-1}e^{-\beta \mathcal{\hat H}}$ and $Z := \mbox{Tr}(e^{-\beta \mathcal{\hat H}})$, is generalized by the KMS condition
$\left \langle \tau_t(\hat A) \hat B \right \rangle = \left \langle \hat B\tau_{t+i\hbar\beta}(\hat A) \right \rangle$.
For convenience, we recall a formal derivation of this from the Gibbs rule and the cyclic property of the trace:
$\left \langle \tau_t(\hat A) \hat B \right \rangle$ $ = Z^{-1}\mbox{Tr}(e^{-\beta \mathcal{\hat H}} e^{i\mathcal{\hat H}t/\hbar} \hat A e^{-i\mathcal{\hat H}t/\hbar} \hat B)$ $ = Z^{-1}\mbox{Tr}(\hat B e^{i\mathcal{\hat H}z/\hbar} \hat A e^{-i\mathcal{\hat H}t/\hbar})$ $ = Z^{-1}\mbox{Tr}(\hat B e^{i\mathcal{\hat H}z/\hbar} \hat A e^{-i\mathcal{\hat H}z/\hbar} e^{-\beta \mathcal{\hat H}})$ $ = \left \langle \hat B\tau_z(\hat A) \right \rangle$
where here we have written $z := t+i\hbar\beta$.
The analyticity of $\tau_z$ in a strip forms the actual substance of the KMS condition.
S Huntsman
  • 361
I will try to explain my intuition which might not be fully accurate. In the path integral form, the vacuum amplitude $Z$ is calculated by considering the sum over all possibilities to start at the vacuum go through some excited states and get back to the vacuum. Roughly speaking, the contribution of a path in configuration space to $Z$ is less significant if its energy is higher than the energy scale of quantum fluctuations given by $\hbar/\tau$ where $\tau$ is the time it takes to traverse the loop in configuration space. In a similar manner, the partition function includes a sum over paths in configuration space and the contribution of a path is determined by its energy in comparison to the thermal energy scale $kT$. In short, $\hbar/\tau$ sets the scale for quantum fluctuations and $kT$ sets the scale of temperature fluctuations, which apart from the imaginary $i$ factor influence the system in roughly the same way.
Khalaf
  • 61
On both sides, there are fluctuations either quantum mechanical or thermal. A random evolution can be naturally formulated in terms of path integral formalism. The randomness is revealed by commutation relation or uncertainty principle if you like.
With commutator algebra, you can always deduce the evolution, without worrying whether $t$ is real or imaginary.
That's my intuition, I'm not sure whether it is "correct" or not.
Machine
  • 2,015
