15
An important aspect of the AdS/CFT correspondence is the recipe to compute correlation functions of a boundary operator $\mathcal{O} $ in terms of the supergravity fields in the interior of the $AdS_{n+1}$ (as we approach the boundary). Namely, $$\big< \exp \int_{\mathbb{S}^n} \mathcal{O} \phi_{0}\big > = Z_{s} \left[\phi \big|_{\partial(AdS)} = \phi_0\right],$$ where $Z_s$ is the supergravity partition function.
The review papers I have found (and Witten's original paper as well) explain how to use the above formula but fail to provide a satisfactory explanation why the formula ought to work, or even how it came about.
Can anyone explain if there is a logical (and/or insightful) path that would lead to the above correspondence between the generating function of the $n$-points correlators and supergravity/string theory?
First, you need to reflect what, in fact, is a CFT. The abstract answer is that
It's a set of correlation functions $\langle O_i(x) O_j(y) \cdots O_k(z) \rangle$ which satisfy certain axioms, like the conformal covariance or the short distance behavior when $x\to y$.
These multi-point functions can be encoded in the generating function, so the same set of axioms can be phrased as
It's a functional $\Gamma[\phi_i]= \langle \exp\int \sum_i O_i(x)\phi_i(x) d\,^nx\rangle$ which satisfies certain set of properties.
Now, consider a gravity theory in an asymptotically AdS spacetime, and consider its partition function given the boundary values of $\phi_i$. It gives a functional
$Z_s(\phi_i|_{\partial(AdS)}=\phi_i)$
This functional automatically satisfies the properties which a CFT generating function satisfies. Conformal covariance comes from the isometry of the AdS, for example. Therefore, abstractly, it is a CFT. (A duck is what quacks like a duck, as a saying goes.)
Now this line of argument does not say why Type IIB on AdS$_5\times$ S$^5$ gives $\mathcal{N}=4$ SYM. For that you need string theory. But everything above this paragraph is just about axiomatics.
So, when there is a consistent theory of gravity on AdS$_{d+1}$ other than string/M-theory, you still get CFT$_d$.
Yuji
  • 3,682
