22
In evaluating the vacuum structure of quantum field theories you need to find the minima of the effective potential including perturbative and nonperturbative corrections where possible.
In supersymmetric theories, you often see the claim that the Kähler potential is the suitable quantity of interest (as the superpotential does not receive quantum corrections). For simplicity, let's consider just the case of a single chiral superfield: $\Phi(x,\theta)=\phi(x)+\theta^\alpha\psi_\alpha(x) + \theta^2 f(x)$ and its complex conjugate. The low-energy action functional that includes the Kähler and superpotential is $$ S[\bar\Phi,\Phi] = \int\!\!\!\mathrm{d}^8z\;K(\bar\Phi,\Phi) + \int\!\!\!\mathrm{d}^6z\;W(\Phi) + \int\!\!\!\mathrm{d}^6\bar{z}\;\bar{W}(\bar\Phi) $$ Keeping only the scalar fields and no spacetime derivatives, the components are $$\begin{align} S[\bar\Phi,\Phi]\big|_{\text{eff.pot.}} = &\int\!\!\!\mathrm{d}^4x\Big(\bar{f}f\,\frac{\partial^2K(\bar\phi,\phi)}{\partial\phi\partial{\bar\phi}} + f\,W'(\phi) + \bar{f}\, W(\phi)\Big) \\ \xrightarrow{f\to f(\phi)} -\!&\int\!\!\!\mathrm{d}^4x\Big(\frac{\partial^2K(\bar\phi,\phi)}{\partial\phi\partial{\bar\phi}}\Big)^{-1}|W'(\phi)|^2 =: -\!\int\!\!\!\mathrm{d}^4x \ V(\bar\phi,\phi) \end{align}$$ where in the second line we solve the (simple) equations of motion for the auxiliary field. The vacua are then the minuma of the effective potential $V(\bar\phi,\phi)$.
However, if you read the old (up to mid 80s) literature on supersymmetry they calculate the effective potential using all of the scalars in the theory, i.e. the Coleman-Weinberg type effective potential using the background/external fields $\Phi(x,\theta)=\phi(x) + \theta^2 f(x)$. This leads to an effective potential $U(\bar\phi,\phi,\bar{f},f)$ which is more than quadratic in the auxiliary fields, so clearly not equivalent to calculating just the Kähler potential. The equivalent superfield object is the Kähler potential + auxiliary fields' potential, as defined in "Supersymmetric effective potential: Superfield approach" (or here). It can be written as $$ S[\bar\Phi,\Phi] = \int\!\!\!\mathrm{d}^8z\;\big(K(\bar\Phi,\Phi) + F(\bar\Phi,\Phi,D^2\Phi,\bar{D}^2\bar{\Phi})\big) + \int\!\!\!\mathrm{d}^6z\;W(\Phi) + \int\!\!\!\mathrm{d}^6\bar{z}\;\bar{W}(\bar\Phi) $$ where $F(\bar\Phi,\Phi,D^2\Phi,\bar{D}^2\bar{\Phi})$ is at least cubic in $D^2\Phi,\bar{D}^2\bar{\Phi}$. The projection to low-energy scalar components of the above gives the effective potential $U(\bar\phi,\phi,\bar{f},f)$ that is in general non-polynomial in the auxiliary fields and so clearly harder to calculate and work with than the quadratic result given above.
So my question is: when did this shift to calculating only the Kähler potential happen and is there a good reason you can ignore the corrections of higher order in the auxiliary fields?
Dilaton
  • 9,771
Simon
  • 3,593
Indeed, your question has nothing to do with the distinction between 1PI and Wilsonian. The answer is that the terms which contain nontrivial dependence on $D^2\Phi$ are to be dropped if the breaking of supersymmetry is small compared to the natural ("supersymmetric") mass scale in the problem. You can see this by noting that the effective potential has to be of the form $f^2 F(f/M^2)$ where $f$ is the SUSY breaking scale and $M$ is some supersymmetric scale (which can the VEV of some modulus, too). Another way to see this is that terms with more powers of $D^2\Phi$ have a higher engineering dimension and thus have to be divided by some SUSY scale, so their effect disappears as f/M^2->0.
In some physical scenarios these corrections could be important, but since in dynamical models having rigorous control over the physics usually entails having SUSY-breaking as a small effect, in most of the literature these terms are dropped.
Zohar Ko
  • 1,665
There are two types of effective actions, the one particle irreducible (1PI) (Coleman-Weinberg) and the Wilsonian.
The variables in the 1PI are the vacuum condensations of the fields, i.e., it is "classical". In principle it is computed by performing the path integral with sources and then replacing the sources by the vacuum condensates through a Legendre transform. This action includes all the quantum corrections of the theory and its potential term determines its vacua. This action needs not be local. In prcatice, this action can be computed only approximately by loop expansion, and its expansion suffers from IR divergences in the case of massless fields.
The second type of effective action is the Wilsonian effective action where the modes of energy beyond some given scale are integrated. The basic variables here are the low energy modes of the fields. This action is quantum mechanical in the sense that it does not include the radiative corrections of the low energy modes and still the path integral on them must be performed. This action is local and does not suffer from IR divergences, for these reasons it is used in supersymmetry breaking computations. Please see the following review by Tanedo (and references therein) describing the distinction between the two types of effective actions in the context of supersymmetry.
Now, regarding to the computation in the first paragraph of the question, if the "tree-level" Kahler potential is used, it is just a computation of the tree scalar potential.
