-6
If black holes are hole in space and time then at bottom or below bottom there is no more gravity of black hole. As any hole has an end (Deepest end). Is this true ?
******** EDIT ***********
http://www.nasa.gov/audience/forstudents/k-4/stories/nasa-knows/what-is-a-black-hole-k4.html
A black hole is a place in space where gravity pulls so much that even light can not get out. The gravity is so strong because matter has been squeezed into a tiny space
https://en.wikipedia.org/wiki/Black_hole
A black hole is a region of spacetime exhibiting such strong gravitational effects that nothing—including particles and electromagnetic radiation such as light—can escape from inside it.[1] The theory of general relativity predicts that a sufficiently compact mass can deform spacetime to form a black hole
As black hole squeezed or create pit or deform spacetime in space time fabric. So at an end of that pit there is no more gravity.
So my question is, is this true?
Sudhir
The holes you are used to seeing most likely occur on Earth. Since Earth's surface is a 2-dimensional object, holes in it are also 2-dimensional. Given that we live in a 3-dimensional world (spatially/geometrically), these holes would then be traversable; leading to a "pit" below. Since it isn't realistic to have a pit that goes completely through Earth, you would then be used to those which have bottoms and nothing below.
The problem with using holes that you are used to as an analogy to a black hole is that black holes exist in 3-dimensional space instead of a 2-dimensional surface. As such, they are spherical; you can enter the black hole from any direction. Given that there are only 3 spatial dimensions, there is no "black pit" with a bottom. That is, below a black hole is exactly the same as above a black hole. This is good because in space there really is no way to define "above" or "below".
A black hole is simply an extremely massive object. It is not a literal 2D hole in space.
Jim
  • 24,676
