I have been reading di Francesco et al's textbook on Conformal Field theory, and am confused by a particular statement they make on pg 22.
Let $\{\psi_i\}$ be a set of Grassmann variables. Starting with the Lagrangian $$L = \frac{i}{2} \psi_i T_{ij} \dot{\psi}_j - V(\psi) \tag{2.32}$$ they derive the equation $$\dot{\psi_i} = -i \, (T^{-1})_{ij} \frac{\partial V}{\partial \psi_j}.\tag{2.36} $$
They then claim that you get the same result if you use the Heisenberg equation of motion $$\dot{\psi} = i [H, \psi]\tag{2.36b}$$ with $$H = V(\psi)\quad\text{and}\quad \{\psi_i,\psi_j\}_{+} = (T^{-1})_{ij}.\tag{2.37}$$
I don't understand how they get from the Heisenberg equation of motion to the desired result. I tried setting $V = \psi_j$ for a particular $j$ and deriving the result in this particular case, but in trying to compute $[\psi_j,\psi_i]$ you'll end up getting extra terms of the form $\psi_i\psi_j$ which I don't know how to get rid of. Unfortunately the textbook doesn't work this out and leaves this as an exercise to the reader.
On a slightly deeper level, what exactly is meant when we say that Grassmann variables provide a "classical" description of Fermi fields?
Any help/insight would be much appreciated!
