Is it possible to create an electromagnetic wave of near zero frequency?
An electromagnetic wave carries energy. If we can make the frequency of an EM wave vanishingly small and make it practicality DC, will it also carry energy? I don't think it is possible. Hence there should be some fundamental limit on the minimum frequency of an EM wave.
Is there any such thing?
hsinghal
  • 2,601
5 Answers5
There is no lower limit on the frequency of electromagnetic fields. One can consider a DC field as the lowest frequency being of zero Hz. Perhaps somebody would argue that to be truly of zero Hz the DC field have to exist for all eternity. However, if one expands the DC field that exists for only a finite duration with a Fourier transform, one obtains a spectrum that is continuous and nonzero at the origin. This shows that nonzero frequencies exist all the way down to zero.
What about the quantum mechanical view of this? As pointed out by tparker, one can get low frequency "soft" photons that contribute to the dynamics. Moreover, DC fields such as the Coulomb field around charged particles are also included in quantum mechanics (or quantum field theory).
One view that is expressed is that the lowest frequency should be determined by some cavity effect due to the size of the universe. However, such a view has a few practical problems. For the universe to act as a cavity, the field must be able to bounce back and forth in it so that it can constructively interfere with itself. This assumes particular boundary conditions. It also assumes that the field will exist for long enough to build up this constructive interference and obviously it must still be coherent with itself for something like that to work correctly. Just thinking about this a little bit, one quickly realized that such requirements are unlikely to be satisfied. Hence, the size of the universe probably does not set a limit to the lowest allowed frequency.
flippiefanus
  • 16,824
In a sense, the size of the universe limits the wavelength of a photon: any photon that has larger wavelength than the size of the universe, cannot exist entirely within this universe. It is not clear that this can ever be tested, however.
In high energy (short wavelength) the lack of a limit to thermal radiated light was an important reason for the ascendancy of early quantum mechanics the violet catastrophe. Classical physics couldn't explain radiant heat flow, because it had no upper photon energy limit. Quantum mechanical atoms DO have such limits (for Hydrogen, it's 13.6 eV = 1 Rydberg).
Whit3rd
  • 10,853
Lowest possible amplitudes and maximum lenght demands very low electric moving charge and voltage, but the wave will disappear, as a ghost.
Yes, extremely low-energy "soft photons" exist and can have important effects even when their energy is too low to be directly detected.
tparker
  • 51,104
-1
Brian Dodson has posted a brief explanation to this at Quora. Basically it is suggested that "the largest energy that is sustainable as an electromagnetic wave is approximately 1 MeV, or a wavelength of 0.01 Angstrom."
https://www.quora.com/Whats-the-longest-possible-wavelength-lowest-possible-frequency-lowest-possible-energy-of-electromagnetic-radiation
Interestingly in my study of Geophysics we actually use VLF (very low frequency) military transmitters to survey geoelectrical properties of the ground, typically in the 3-30kHz bands.
Jay
  • 49
