29
In my physics lessons, my teachers have always been keen to tell my class that Jupiter is considered a 'failed star' by scientists. Is this true?
In my own effort I wondered if maybe this could just be being regurgitated from an outdated physics syllabus that still considers the Solar System to have nine planets. From that thought onward, through my research on the Internet, I haven't found people referring to Jupiter as such and people always call it a planet rather than a brown dwarf.
Furthermore, it's my understanding that brown dwarfs possess more mass than Jupiter suggesting to me that Jupiter possesses too little mass for fusion to even be plausible.
So am I correct in thinking that Jupiter is 'only' a planet, or are my physics teachers correct in saying it is a failed star (and if so, why)?
alexjohnj
  • 545
The answer kind of depends on how old you are. At a very introductory level, say, maybe middle school or younger, it's "okay" to refer to Jupiter as a failed star to get the idea across that a gas giant planet is sort of similar to a star in composition. But around middle school and above (where "middle school" refers to around 6-8 grade, or age ~12-14), I think you can get into enough detail in science class where this is fairly inaccurate.
If you ignore that the solar system is dominated by the Sun and just focus on mass, Jupiter is roughly 80x lighter than the lightest star that undergoes fusion. So it would need to have accumulated 80 times what it already has in order to be a "real star." No Solar System formation model indicates this was remotely possible, which is why I personally don't like to think of it as a "failed star."
Below 80 MJ (where MJ is short for "Jupiter masses"), objects are considered to be brown dwarf stars -- the "real" "failed stars." Brown dwarfs do not have enough mass to fuse hydrogen into helium and produce energy that way, but they do still produce their own heat and glow in the infrared because of that. Their heat is generated by gravitational contraction.
And Jupiter also produces heat through both gravitational contraction and differentiation (heavy elements sinking, light elements rising).
Astronomers are not very good at drawing boundaries these days, mostly because when these terms were created, we didn't know of a continuum of objects. There were gas giant planets, like Jupiter and Saturn, and there were brown dwarf stars, and there were full-fledged stars. The line between brown dwarf and gas giant - to my knowledge - has not been drawn. Personally, and I think I remember reading somewhere, the general consensus is that around 10-20 MJ is the boundary between a gas giant planet and brown dwarf, but I think it's fairly arbitrary, much like what's a planet vs. minor planet, Kuiper belt object (KBO) or asteroid.
So during Solar System formation, was there a chance Jupiter could have been a star and it failed ("failed star!") because the mean Sun gobbled up all the mass? Not really, at least not in our solar system. But for getting the very basic concept across of going from a gas giant planet to a star, calling Jupiter a "failed star" can be a useful analogy.
it might be more accurate to say that our solar system is to some extent a failed binary star system - as there are stars out there with exoplanets in the 'brown dwarf range' of mass - if our star system had enough mass initially to result in such an arrangement, there probably wouldn't be an earthlike planet around for us to exist on and see it up close, but there could have been enough mass in total for very large a exoplanet to ignite.
-1
Well Jupiter is not really a failed star. It is considered that because it has 2.5 times all the mass if all the other planets were added together. However Jupiter has the materials of a star it lacks the mass. It has to be a minimum 80 times more massive to even be a low mass star(red dwarf). The sun has 1000 masses of Jupiter and even it is only a medium mass star. So in a sense Jupiter is a failed star but not really. There was never enough mass in the accresion disk to give Jupiter even more mass than now. At the very least it would have gotten a little bit more mass than it has now if things in the past of our solar system played very differently but still nowhere near the mass of even a low mass star. In the end Jupiter is only a planet(though a very special and massive one). Even with all the 8 planets merged into one planet, it would only be slightly more massive than Jupiter itself. Around 40% more massive than Jupiter.
Roghan Arun
  • 1,554
