28
My understanding is that elements heavier than iron and nickel are not formed in a star but, can heavy elements such as lead and others be present/found in a star's core ?
I ask because the following document
http://arxiv.org/abs/astro-ph/0410628
gives the impression that lead and other heavy elements may be found in a star's core and I thought that was not possible.
5 Answers5
22
It is a myth that heavier elements than iron are not produced in stars, slow-neutron-capture-process is a nucleosynthesis process that occurs at relatively low neutron density and intermediate temperature conditions in large stars. For details of what elements are produced and about the process itself, see s-process.
ProfRob
  • 141,325
19
The heavier-than-iron elements are not formed during stellar fusion, but they are formed during supernovae. Then the oldest stars cannot have these heavier elements, but new generations, formed from 'recycled' material of other stars that went supernova can.
See Stellar populations .
There are heavier that iron elements on Earth, the Earth was formed from the same stuff clumping together that the sun was, so some fraction of such elements should also be present in the sun.
EDIT: Sorry, I forgot about the s-process that Wolphram jonny mentioned, thanks for that. The process in supernovae that I mentioned is the r-process.
spender
  • 177
Gerben
  • 405
14
The star that is studied in the paper that you refer to is a very old, very metal-poor "Uranium giant". This is an evolved star with a very deep convective envelope.
The Uranium and Thorium that are seen in the atmosphere of the star were not produced in the star. They would have been produced, via the r-process neutron capture mechanism, in the supernova explosion of an earlier, massive star. These elements are notable because elements heavier than lead must have been produced in supernovae.
The U and Th in the supernova ejecta (along with full range of other heavy elements in various proportions) were mixed into the material that formed the star we are talking about here. Those elements would have been present in the core and throughout the whole of the star.
The paper you reference attempts to find the lead content of the star. Lead can be produced by the s-process inside evolved giant stars, by slow neutron capture onto existing iron-peak nuclei. However, in a very metal-poor star, this is likely to be ineffective, and/or has not had time to occur in previous stellar generations and the paper argues that the small amount of lead that is found is consistent with the radioactive decay of (some of) the r-process Uranium and Thorium already in the star when it formed. The lead would also be found all the way through to the core of the star.
As an aside, the effectiveness of the s-process in stars that already have some iron in them, means that about half the heavy element abundance of the solar system was created inside stars and not in supernova explosions. The Sun does contain most of the iron-peak and stable heavier elements in its core and envelope, but these were not produced in the Sun; they were in the material it was born from.
ProfRob
  • 141,325
I'm guessing (and I guess breaking the rules, but I'm interested whether my intuition is at all accurate): I've always assumed that although stellar fusion stops at iron, there is plentiful energy from the prior fusion processes available to create the elements heavier than iron, albeit at a net loss of energy. In decreasing and exponentially smaller amounts the further up the periodic table you climb, obviously, but in a star "exponentially smaller" is seriously relative. Not being a physicist, I have no idea if these further products would be broken down...i.e. would they survive? That they are created within a star (whether during a nova event or otherwise) is not, as far as I am aware, debatable. A tiny loss of energy in a tiny part of a star...it's a little like life -- a suspension of entropy (I really hesitate to say reversal) -- because we have an open system with a humungous fusion generator allowing "unlikely" local phenomena to persist.
Colin
  • 29
Yes. Not only supernovae produce elements heavier than iron, many even heavier elements are produced in dying low mas stars. Here is the table of nucleosynthesis from Wikipedia Commons:
Looks like dying low mass stars even produce lead and other very heavy elements.
Synthesis of elements as heavy as Amercium once has been suspected during explosion of the supernova of the Crab nebula, but later these results were not confirmed.
