Disclaimer: I know this is a vague question, so if this is not the appropriate thread, please direct me to the correct one.
On page 5 of Anthony Zee's Quantum Field Theory in a Nutshell he speaks of a "harmonic paradigm". He uses this term to describe physical theories which are based on studying the excitations of a field, like QFT and String theory do. He is surprised by the fact that even after 75 years we still rely on basic notions of oscillations and wave packets for our physical theories and have not yet found an alternative formulation.
My questions are:
  • What makes this "harmonic paradigm" so useful?
  • What, if any, alternative formulations have been proposed?
rpf
  • 151
Purely mathematically, a function $f(x)$ (that can be differentiated enough times and so on) can be Taylor expanded around a point $a$ as \begin{equation} f(x) = f(a) + (x-a) f'(a)+\frac{(x-a)^2}{2}f''(a)+.. \end{equation} Now if we're describing a physical system with $f$ and the point $a$ is an equilibrium of the system, $f'(a)=0$. Then we have \begin{equation} f(x) = f(a) + \frac{(x-a)^2}{2}f''(a)+.. \end{equation} We see that when describing the behaviour around an equilibrium, the simplest nontrivial approximation is of the form $x^2$, harmonic. Hence, the universal importance of the harmonic oscillator.
Gerben
  • 405
This might help you out a bit: In what sense is a quantum field an infinite set of harmonic oscillators?
From my understanding, most people think it provides a useful way to conceptualize uncoupled quantum fields physically. It doesn't, however, work for coupled quantum fields.
The main problem with this seems to be that infinite harmonic oscillators give you an infinite vacuum energy, something physicists work around through renormalization (basically looking only at energy differences instead of total energy). Some people are satisfied with this, some aren't.
Klauber, as mentioned in the question linked, published this paper in 2003, where he claims to have worked out a solution to this problem (see section 4 of the paper). I've looked at this paper and I didn't really understand it, so I can't verify if his claims are true, but section 4 seems to offer something of an alternative formulation (or at least a solution to the infinite energy problem).
Hopefully that helps!
Akorl
  • 118
