Entropy is a state function. This means that in every cyclical transformation (i.e. a transformation in which the initial and final states are the same) we have
$$\Delta S=0$$
That is to say: every cyclical transformation is isentropic.
But clearly there are cyclical transformation that are neither adiabatic nor reversible. Let's take the following example: a cylindrical container containing a perfect gas, with a movable adiabatic piston and in thermal contact with a large heat reservoir at temperature T.
The state of the system is initially $(P,V,T)$ where $T$ is the temperature of the reservoir and $P$ is the external pressure (let's assume that the piston's weight is negligible). If you quickly compress the gas pushing the movable piston, heat will be produced, which will flow to the heat reservoir. Now if you remove the force pushing the piston, the system will return to its original $(P,V,T)$ state.
The process was clearly non-adiabatic and irreversible, but since initial and final state are the same, it was isentropic.
Another example: let's make the cylinder of the previous example adiabatic. From the initial state $(P,V,T)$, we irreversibly (i.e. quickly, suddenly) push the piston downwards, taking the system to the state $(P',V',T')$. Now we irreversibly pull the piston back to its original position so that the final volume is $V''=V$. Since $P''=P$ also, from the ideal gas law $T''=T$, so we have performed a cyclical, adiabatic, irreversible transformation.
So isentropic+adiabatic doesn't imply reversible.
Conversely, it is easy to see that a reversible adiabatic process must be isentropic.
That's because for a reversible process we have
$$\Delta S_{AB} = \int_A^B \frac{\delta Q}{T}$$
If the process is also adiabatic $\delta Q=0$, so that $\Delta S_{AB}=0$.
Update
I would like to add some more things and clarify what I tried to say. For an irreversible process, we have
$$\Delta S_{AB} > \int_A^B \frac{\delta Q}{T}$$
we have already seen that
$$\text{adiabatic}+\text{reversible} \Rightarrow \text{isentropic} \ (\Delta S =0)$$
From the previous equation we see that
$$\text{adiabatic}+\text{irreversible} \Rightarrow \Delta S >0$$
For a general process, we have
$$\Delta S_{AB} \geq \int_A^B \frac{\delta Q}{T}$$
If the process is adiabatic and isentropic, we obtain
$$0 \geq 0$$
which is trivially verified and tells us nothing about reversibility or irreversibility. So we cannot, if my reasoning is correct, conclude that
$$\text{adiabatic}+\text{isentropic} \Rightarrow \text{reversible}$$
