In the $U(1)$-Peccei-Quinn-Symmetry an axion field $a$ is introduced in order to solve the strong CP-Problem. It is said, that below a certain scale $f_{a}$ this symmetry is broken and you are able to write the field as $a = \langle a\rangle +\,a_\mathrm{phy}$ where $\langle a\rangle$ is the VEV and $a_\mathrm{phy}$ denotes the physical axion field, that is associated with the axion particle.
The VEV is $\langle a\rangle = -\theta f_{a}$ and so the CP-Violating term vanishes, since: $\mathcal{L} \supset (a/f_{a} + \theta) G \tilde{G}$. This is what I've understood so far. However, what I am wondering about now is: Why doesn't the interaction term $\mathcal{L} \supset a_\mathrm{phy} \,G\,\tilde{G}$ violate CP-Symmetry? The only possibility I see is if $a_\mathrm{phy}$ also transforms under CP-Symmetry but I wasn't able to find anything about that.
What I'm also not able to understand is: Why is the symmetry breaking scale parameter $f_a$ also called the decay constant of the axion? I'm not sure why these two are equivalent in this context.
