The equation of motion of a damped oscillator $$\frac{d^2x}{dt^2}+\gamma\frac{dx}{dt}+\omega_0^2x=0$$ which is invariant under time-translation $t\rightarrow t+a$, but not under time reversal $t\rightarrow -t$. We also find that this system does not conserve energy. However, we know from classical mechanics that the time-translation invariace is related to the conservation of the energy not the time reversal. Why does the system dissipate energy?
Time-reversal invariance is related to reversibility, and as I understand not to dissipation directly.
SRS
  • 27,790
  • 13
  • 115
  • 365
To apply Noether's theorem, which is what you are alluding to here, one needs to look at continuous symmetries of a Lagrangian description of a system's dynamics.
The damped oscillation equation you have written, although it is invariant with respect to a time translation as you rightly say, is not a Lagrangian description. If you write the Lagrangian for this system, you'll find that it is not time shift invariant, so this lack of symmetry is where your implied argument ("my description does not depend on time $\rightarrow$ energy is conserved") breaks down.
Some dissipative systems have Lagrangian descriptions but they always wind up with time varying Lagrangians, so there is no contradiction of Noether's theorem: See Joseph Johnson's answer and link to read about some interesting historical attempts to broaden the Lagrangian notion to all systems here.
Incidentally, if you want to model this kind of thing in quantum mechanics, a way to do this is to embed your oscillator in a huge set of coupled quantum mechanical oscillators where your initially excited oscillator is coupled weakly to all the others. The system as a whole varies unitarily with time, so there is no overall dissipation, but if one oscillator begins in a raised state with all others in their ground state, the amplitude to find the oscillator in its excited state dwindles exponentially with time and the energy becomes inexorably spread throughout the whole system of oscillators - a lovely illustration of a simple macroscopically "irreversible" (but microscopically reversible) system. You can do the same in theory with a classical harmonic oscillator too - embed it in a huge system of oscillators and couple it weakly to a huge reservoir of others: the same thing happens. The oscillator on its own follows a damped equation, even though the whole system is not dissipative.
Selene Routley
  • 90,184
  • 198
  • 428
Conservation of energy is related to time translation invariance for systems that can be described by a Lagrangian. Dissipative systems in general are not describable by Lagrangian mechanics (without altering the formalism that is) and so Noether's theorem cannot be applied to check whether or not energy is conserved.
EDIT: the dissipative system the OP refers to admits lagrangians that enable to recover the right equation of motion as pointed out by Valter Moretti, but then the hypotheses under which Noether's theorem holds are not met by such lagrangians.
gatsu
  • 7,550
