The Universe's densest objects are black holes. In the second place, there are neutron stars.
So, if a neutron star compresses to its Schwarzschild radius, would it appear as a black hole? That black hole would be one of the most dense objects in the universe?
Garmen1778
  • 1,541
Actually, before you got to the Schwarzschild radius, the pressure previously supporting the neutron star against its own gravity would no longer be able to do so, and the entire star would violently collapse. Some matter would be thrown out, while the rest would become a black hole. The singularity at the center would be among all the rest of the singularities at the centers of all other black holes for the densest objects in the Universe.
Andrew
  • 9,597
10
An important point to make is that it is not possible for a neutron star to shrink "gradually" so that it disappears quietly inside its own event horizon. There will always be some sort of violent collapse because a neutron star becomes unstable at radii significantly larger than the Schwarzschild radius.
A neutron star which gains mass could shrink. This is because the equation of state is temperature independent and may have a density dependence such that the mass-radius relation results in more massive neutron stars being smaller. (This is definitely true for ideal neutron degeneracy pressure, but the equation of state in a neutron star is far more complicated than that - a neutron star supported only by neutron degeneracy pressure could never exceed $0.7M_{\odot}$, the original TOV limit!)
However, there are limits imposed by causality and General Relativity on the structure of neutron stars. In "Black Holes, White Dwarfs and Neutron Stars" by Shapiro & Teukolsky, (pp.260-261), it is shown, approximately, that even if the equation of state hardens to the point where the speed of sound equals the speed of light, that $(GM/Rc^2)<0.405$.
The Schwarzschild radius is $R_s=2GM/c^2$ and therefore $R > 1.23 R_s$ for stability. This limit is reached for a neutron star with $M \simeq 3.5 M_{\odot}$. A more accurate treatment in Lattimer (2013) suggests that a maximally compact neutron star has $R\geq 1.41R_s$.
If the equation of state is softer, then collapse will occur at smaller masses, and higher densities but at a similar multiple of $R_s$.
Thus there will always be some sort of violent collapse event associated with accretion onto a neutron star that then exceeds the TOV limit.
The picture below (from Demorest et al. 2010) shows the mass-radius relations for a wide variety of equations of state. The limits in the top-left of the diagram indicate the limits imposed by (most stringently) the speed of sound being the speed of light (labelled "causality" and which gives radii slightly larger than Shapiro & Teukolsky's approximate result) and then in the very top left, the border marked by "GR" coincides with the Schwarzschild radius. Real neutron stars become unstable where their mass-radius curves peak, so their radii are always significantly greater than $R_s$ at all masses.
Neutron star mass-radius relations
ProfRob
  • 141,325
Just to add a little (especially to @dmckee's comment to @Florin_Andrei's response):
A typical, isolated neutron star stably resists gravity with neutron degeneracy pressure. If instead it is accreting mass from a binary companion, it may grow beyond the Tolman-Oppenheimer-Volkoff Limit (just like the Schwarzschild limit for white-dwarfs, except for neutron stars), at which point it will inevitably succumb to gravity and collapse.
Neutron-star collapse is believed to almost always form a black-hole remnant; the exact details are unknown, but there are numerous quite successful models. What exactly it would look like is unclear, but the emission would be much less than the supernova of a typical massive star, or white dwarf. The observational signature would be entirely unlike a type Ia, and most likely unlike a type II as-well.
