Apparently light can be sent out in very narrow beams. That is easy to understand as particles. However, I don’t know of any way to send waves as a narrow beam. Of course I’m thinking of things like waves in water. Waves in water could be narrow with linear fronts to the waves if it is contained between 2 walls, but as soon as it exits the walls it will spread out in circular form. What’s the deal with light? How can light as waves go in a narrow beam?
Asked
Active
Viewed 267 times
If you have a beam of light that is a millimeter wide (1/25th of an inch), then its width is approximately 2000 times the wavelength (since the wavelength of visible light is ~400-700 billionths of a meter, depending on color).
Due to diffraction, that means that the beam will spread out by roughly 1 unit for every 2000 units it travels: send the beam down the length of a football field and it will be narrower than a football.
Water waves typically are much closer to the size of the gap they pass through (say, ocean waves through the mouth of a harbor) and so they spread out a lot more.
DMPalmer
- 734
