The equivalent problems are also found in Marion problem 7-22, and other formal classical mechanics textbook. Here what i want to know why instructor solution and some websites gives this kinds of approach.
A particle of mass m moves in one dimension under the influence of a force \begin{align} F(x,t) = -k x^{-2} exp(-t/τ) \end{align} where k and τ are positive constants.
what i want to do is compute its lagrangian.
\begin{align} & F(x,t) = - \frac{\partial U(x,t)}{\partial x}, \end{align}
First i know that this kinds of approach (The $F=-\nabla U$ is only holds for conservative forces, $i.e$, path-independent, position dependence potential), is vaild indeed
Many similar textbook, and their solution used above relation to rederive $U$, and compute $L$ and $H$.
I think their purpose is to show that even if $H$ is written as $H=T+U$, this $H$ is different from $E$. $i.e$, even though $H$ is written as $H=T+U$, since the force is depend on time explicitly, $H$ is no longer $E$.
I understand the procedure but not accept the first part. In general (?) i know that time dependent force is non-conservative force. Am i wrong? Does $F=-\frac{\partial U}{\partial x}$ kinds of thing always holds?
cf, from wiki
Mathematical description[edit] A force field F, defined everywhere in space (or within a simply-connected volume of space), is called a conservative force or conservative vector field if it meets any of these three equivalent conditions:
  1. The curl of F is the zero vector: \begin{align} \nabla \times \vec{F} = \vec{0}. \, \end{align}
  2. There is zero net work (W) done by the force when moving a particle through a trajectory that starts and ends in the same place:
    \begin{align} W \equiv \oint_C \vec{F} \cdot \mathrm{d}\vec r = 0.\, \end{align}
  3. The force can be written as the negative gradient of a potential, \begin{align} \Phi: \vec{F} = -\nabla \Phi. \, \end{align}
phy_math
  • 3,782
If you are wondering if $F=\frac{-\partial U}{\partial x}$ holds, you may check the equivalent condition that you posted, $\nabla\times\vec{F}=0$. In this case the curl will come out to be zero, so you may then proceed to write the force as the negative gradient of a potential. This appears to work because the del operator is not taking time into account, only the path. That is where the hamiltonian then comes in.
In this case, they are not saying that $H\neq E$ because of the time dependence. Since $H=U+T$ and $E=U+T$, here $H=E$ (though this is not always the case). Since H contains time explicitly, H is not a conserved quantity. Since $H=E$, energy is therefore not conserved even though the force appeared to be conservative. That is what they were demonstrating. If $H\neq E$, then H not being a conserved quantity would be irrelevant to whether energy was conserved or not.
