I noticed recently that for many field equations, Lagrangian evaluated on-shell (i.e. using equations of motions) is a full derivative- a divergence or something, or in other words a boundary term. This is true for Weyl, Dirac, Klein-Gordon (without external potential), Maxwell, classical Schrodinger. I am wondering if these are special cases of some general pattern or principle.
Theorem: let $L$ be a homogeneous function of degree $k$; then the on-shell lagrangian is a total derivative.
Proof: according to the Euler's homogeneous function theorem, $$ k\ L(q,\dot q)=q\frac{\partial L}{\partial q}+\dot q\frac{\partial L}{\partial \dot q}\tag{1} $$
On the other hand, because of the Euler-Lagrange equations, $$ (1)=q\frac{\partial L}{\partial q}+\dot q\frac{\partial L}{\partial \dot q}\stackrel{\mathrm{EL}}{=}q\frac{\mathrm d}{\mathrm dt}\left(\frac{\partial L}{\partial \dot q}\right)+\dot q\frac{\partial L}{\partial \dot q} \tag{2} $$
Finally, integrating by parts, $$ (2)=q\frac{\mathrm d}{\mathrm dt}\left(\frac{\partial L}{\partial \dot q}\right)+\dot q\frac{\partial L}{\partial \dot q}\stackrel{\mathrm{IBP}}{=}-\dot q\frac{\partial L}{\partial \dot q}+\dot q\frac{\partial L}{\partial \dot q}+\text{total derivative}=\text{total derivative}\tag{3} $$ which is what we wanted to prove. The generalisation to field theory is straightforward.
As for an example of a non-homogeneous lagrangian, take $$ L=\frac{1}{2}\dot q^2+\mathrm e^q\tag{4} $$ which, when evaluated on-shell, is $$ L=\mathrm e^q\left(1-\frac{q}{2}\right)\tag{5} $$ i.e., this is not a total derivative. For a more realistic example, see QMechanics comment above ("a non-relativistic point particle in a uniform gravitational field").
- 56,647
