In $F=kma$, $k=1$ but in $F=kx$, $k$ is not equal to 1?So what are the conditions for the constant of proportionality to be set 1?
I think this question has been asked already several times, for example :
How do we know that $F = ma$, not $F = k \cdot ma$
Are Newton's "laws" of motion laws or definitions of force and mass?
Why isn't it $E \approx 27.642 \times mc^2$?
Constants of proportionality depend on the nature of the equation and the system of units. Their values can be chosen for convenience when a physical unit is being defined; otherwise the value is determined by other physical units or by nature.
$F=ma$ is being used to define the unit of force as a derived unit, based on the units for mass and acceleration. For convenience $k$ has been chosen as $1$, but any value could be used instead. (See Coulomb's Equation below.) Similar is $E={\frac Fq}$ which is being used to define electric field strength.
$F={\frac{GmM}{r^2}}$ is a universal law : it applies to every pair of masses in the universe. The value of the constant $G$ is decided by nature because all the other quantities ($F$, $m$, $r$) have defined units.
$F=kx$ is not being used to define anything : units for $F$ and $x$ are already defined. But it is not a universal law : it is an approximation which applies to many different materials and situations - eg the extension of springs and wires, the bending or sagging of beams, the deformation of pneumatic tyres. So there are really many different equations $F=kx$, each with a different value of $k$, which like $G$ can only be found by experiment. We cannot set $k = 1$ because we don't have a choice. We can make the equation less situation-dependent by writing it in terms of stress and strain : ${\frac FA}=Y{\frac xL}$. The constant of proportionality $Y$ (Young's Modulus) then applies to a particular material at a particular temperature - unlike $G$ it is not a universal constant.
$F={\frac{kqQ}{r^2}}$ is another universal law. In the gaussian/cgs/electrostatic system of units $k$ is chosen to be $1$ and this equation is used to define the unit of charge $Q$, the esu (also called statcoulomb or franklin). In SI, units are already defined for $F$, $Q$ and $r$. The value of $k$ (Coulomb's constant) is universal and determined by nature. However, this $k$ is related through Maxwell's equations of electromagnetism to the magnetic constant $\mu_0$ and the speed of light $c$. For convenience it is written as $k ={ \frac 1{4\pi \epsilon_0}}$ while the values of $\mu_0$ and $\epsilon_0$ are chosen to make the tidy equation $\mu_0\epsilon_0 c^2=1$. See the Wiki article for more about this.
https://en.wikipedia.org/wiki/Vacuum_permittivity#Historical_origin_of_the_parameter_.CE.B50
- 27,586
