If we stick two block masses by a string and pass it over a pully and let the blocks free then mathematically we can obtain that the whole weight on the pully is more if the blocks are kept at rest, than if the heavy block is allowed to fall freely. But what is the physical meaning of it?
Any time you have an equal and opposite force acting on two bodies, the effect is proportional to $\frac{1}{m}$ for each one.
The combined effect is proportional to $$\text{(effect)} = \left( \frac{1}{m_1} + \frac{1}{m_2} \right) \text{(action)}$$
When inverted to find which action has a desired effect we get the reduced mass
$$ \text{(action)} = \left( \frac{1}{m_1} + \frac{1}{m_2} \right)^{-1} \text{(effect)} = \frac{m_1 m_2}{m_1+m_2} \text{(effect)} $$
This concept applies to any interaction between two things, like for example:
  • Two masses attached to a spring, rod or rope.
  • Two masses under gravity.
  • Two masses under electrostatics.
  • Two objects colliding
and probably many more.
John Alexiou
  • 40,139
When you state that the two masses are 'kept at rest' I assume you mean that the pulley is prevented from turning. The load on the pulley is then $(M+m)g$.
[If the pulley is not prevented from turning, then to keep the masses at rest we would have to lift the heavier mass $M$ until it became, effectively, the same weight as the smaller mass. The total load on the pulley is then $2mg$. Alternatively we could pull down on the lighter mass $m$ to make it as heavy as the larger mass $M$. The total load on the pulley is then $2Mg$.]
If the pulley is not prevented from turning, the tension $T$ in the string is the same on both sides of the pulley. The load supported by the pulley is $2T$.
Write the equations of motion for the two masses $M$ and $m$ : $$Mg - T = Ma$$ and $$T - mg = ma$$ where $a$ is the common acceleration of the two masses. Subtracting we get : $$2T = (M+m)g - (M-m)a$$ which is less than $(M+m)g$ because $M\gt m$ and $a\gt 0$.
So the load on the pulley is less if the pulley can turn freely and the heavier mass is allowed to fall.
lucas
  • 3,199
sammy gerbil
  • 27,586
When the blocks are kept at rest , for the vertical equilibrium the pulley has to exert the force equal to the weight of two blocks. But when the heavier block starts moving down the mechanical advantage of pulley with respect to the heavier block increases and hence the weight on the pulley decreases.
