I can't imagine such phenomenon. Would it becomes an ellipsoid, or maybe a straight line?
What you are referring to is a special case of the Ehrenfest Paradox
In its original formulation as presented by Paul Ehrenfest 1909 in relation to the concept of Born rigidity within special relativity,1 it discusses an ideally rigid cylinder that is made to rotate about its axis of symmetry. The radius R as seen in the laboratory frame is always perpendicular to its motion and should therefore be equal to its value R0 when stationary. However, the circumference (2πR) should appear Lorentz-contracted to a smaller value than at rest, by the usual factor γ. This leads to the contradiction that R=R0 and R
The paradox has been deepened further by Albert Einstein, who showed that since measuring rods aligned along the periphery and moving with it should appear contracted, more would fit around the circumference, which would thus measure greater than 2πR. This indicates that geometry is non-Euclidean for rotating observers, and was important for Einstein's development of general relativity.
