There is a special variant of time dilation paradox bugs me.
  1. Imagine there are 2 small spaceships moving toward each other in constant speed. Each ship has an observer on-board.
  2. According to both observers, if nothing else happen, the 2 ships are going to collide in exactly 10 seconds.
  3. The relative speed between the 2 ships are high. Each observer may observe a time dilation effect to slow time in the other ship by 50% than his own ship. (If I understand time dilation correctly, this is what happens)
  4. One spaceship has a special timed-bomb on it ticking.
  5. According to the observer on-board this "bomb ship", the bomb ticks at "normal speed" and will implode exactly 9 seconds later. That will prevent the collision from happening.
  6. However, according the the other ship, the bomb's clock ticking 50% slower. Hence the bomb will go off 18 seconds later. That means the ships will collide before the bomb implode.
So what will happen 10 seconds later? Will the 2 ships collide? Or will the bomb ship implode before that?
Update: To keep things closer to the point I puzzled, I would add some initial factor here:
  1. Both ship is approaching to each another on an orbit. They starts the same coordination.
  2. Both ship has a clock synchronized with each another before start. The clocks were counting down to the collision time (0s).
  3. According to these settings, the bomb will go off when the count down clocks on its ship says "1s".
Let's say that the "safe ship" is (A) and "bomb ship" is (B).
As @alfred-centauri stated, their clock will agree each other when they meet (if the bomb wasn't go off) on count down "0s". For time-dilation to stand, both observer should observe an earlier start time so they can match when meet.
i.e. when clock on (A) says "20s", the clock (B) observed on (A) should be "10s" (plus some time for the information to reach (A)).
From (A) point of view, (B) clock must have ran faster before that so it can run slower now. Isn't that strange? Or what did I got wrong? What would these ship observes in their final journey?
For concreteness, stipulate that both spaceship's clocks will read 0 at the instant of the collision (assuming the bomb does not explode first).
Now consider the following question regarding the spaceship without a bomb: when the spaceship's clock reads t = -10s, what is the time observed on the other spaceship's clock?
Clearly, if the other clock is observed to run slow by 50%, the answer is $t' = -5s$. Thus, the timer on the bomb is observed to have $4.5s$ remaining and so, according to both observers, the bomb will explode before the collision.
