What will happen if we somehow create an "anti-sodium "element and react it with "hydrogen"(not anti)?
I am specific about ANTI-SODIUM and HYDROGEN. Not just plain matter and antimatter.
The annihilation of electrons and positrons goes cleanly to two photons, but the annihilation of brayons and antibaryons is a far more complicated process. This is because baryons are composite particles made up from (on average) three quarks. I discuss this in Are there different kinds of antimatter reactions?, where I show that a proton-antiproton annihilation can produce a spray of nine charged particles:
Proton-antiproton annihilation
In your question you ask about the reaction of a proton with an anti-sodium nucleus, and this is likely to be even messier. The complete annihilation of a proton and antiproton could liberate up to 2GeV of energy, but the binding energy of the nucleons in a sodium nucleus is only about 8 - 9 MeV per nucleon, which is two hundred times smaller.
The result is likely to be that the annihilation will disrupt the anti-sodium nucleus and produce a spray of pions and anti-alpha particles. Exactly what would happen is hard to predict, but it would be messy. It's very, very unlikely that the proton would neatly annihilate a single antiproton in the anti-sodium nucleus to leave anti-neon.
Although we've never made an anti-sodium nucleus, the reaction would be the same as an antiproton reacting with sodium except with the particles and antiparticles switched and of course we could do this experiment. However I've been unable to find any data on antiproton-sodium reactions.
John Rennie
  • 367,598
We would get anti-Neon... and some anti-fluorine from hydrogen anti-Neon collission
Ref: https://www.quora.com/If-I-could-manage-to-fill-a-glass-with-anti-hydrogen-and-mixed-it-with-an-equal-amount-of-water-would-it-produce-oxygen
This is science fiction:
As John notes it is very hard to make antimatter: antiprotons are easily made in proton proton scattering, and positron with gammas, but as we know, the energy levels at which the electron is trapped about a proton is of electron volt order of magnitude so the positron and the antiproton have to be cooled and brought together so that the antihydrogen can form. This has been done.
Let us suppose we want to go to anti- deuterium. One needs an antiproton and an antineutron, but neutrons and antineutrons are a not manageable because it is only with magnetic fields that one can control them, at low energies, and the antineutrons generated in parallel mechanisms during the production of antiprotons have high energies and become part of the radiation environment.Trapped cold neutrons come from reactor technologies, but it is hard to see how one could trap the energetic antineutrons to cool them so as to bind into a deuterium nucleus, to start with. Only if neutron oscillations are there, but if this is observed, then a lot of the standard model physics will have to be reexamined.
As just a simple antiproton antineutron nucleus as the antideuron has impossible experimental logistics, the build up of antinuclei with a number of antiprotons and antineutrons becomes science fiction.
It is true though, that quantum mechanics is such, that if enough energy exists in a proton scattering beam, a whole nucleus-antinucleus pair will have a quantum mechanical probability to be generated, as proton-antiproton pairs are generated. This mechanism is not even considered in the standard model of cosmology, I suppose because the probabilities are infinitesimally small.
John has answered for the result of this science fiction experiment.
anna v
  • 236,935
