Intuitively (at least to me) it seems that the answer should be "yes", since a fictitious force arises due to being in a non-inertial frame; the frame is accelerating, but the objects within this frame (neglecting any other forces) and so they will remain at rest (or at constant velocity), however, relative to an observer in this non-inertial frame, they will all seem to accelerate in the opposite direction at the same rate.
If the above is correct, then this notion can be shown mathematically as follows (at least, I think). Newton's 2nd law states that the acceleration, $\mathbf{a}$ of a massive object (due to an applied force) is proportional to the force, $\mathbf{F}$ acting on it, such that $\mathbf{F}=m\mathbf{a}$, where the mass $m$ of the object is the constant of proportionality. This does not define the force (by which I mean it doesn't give a mathematical expression describing the force, for example, the Coulomb force is defined by the mathematical expression $\mathbf{F}_{C}=\frac{1}{4\pi\varepsilon_{0}}\frac{q_{1}q_{2}}{r^{2}}\hat{\mathbf{r}}$ which is equal to $m\mathbf{a}$). However, in the case of a fictitious force, $\mathbf{F}_{fic}$, the force is defined by the mathematical expression $\mathbf{F}_{fic}=-m\mathbf{a}_{inert}$, where $\mathbf{a}_{inert}$ is the acceleration of the reference frame. It has this form since it is introduced to account for the acceleration of the reference frame. Then, by Newton's 2nd law, assuming that no other forces are acting, we have that $$-m\mathbf{a}_{inert}=m\mathbf{a}\Rightarrow\mathbf{a}=\mathbf{a}_{inert}$$ i.e. the acceleration of each of the objects due to this fictitious force is independent of its mass.
I'm unsure though whether I've conducted this analysis completely correctly though, so any feedback would be much appreciated.
user35305
  • 3,327
The acceleration of an object by fictitious forces is by the definition of what a fictitious force is due to the acceleration of the non inertial reference frame only and does not depend on its mass.
In order to make Newtonian mechanics work in those non inertial frames these fictitious forces are introduced and defined to be equal to the mass times the acceleration of the non inertial frame.
See for example: How fictitious are fictitious forces?
Jan Bos
  • 851
