Say I'm holding a rod composed of an incomprehensible solid, and this solid rod is 1 light second long. Then say I poke you with the rod and at the same time I flash a light on you. If light is the universal speed limit, then you should see the light before you feel the annoying poke. But if the rod is incompressible, where is the delay?
Asked
Active
Viewed 142 times
There is no such material as "Non-compressible" to that extent -
Even in a "least-compressible" rod, the push itself would be carried by electromagnetic forces from atom to atom. These forces also can not travel faster than light. So, the poke can not reach before light.
The delay is inside the rod. Meaning the movement does not reach the other end faster than light. Or you can say, there is no such material.
kpv
- 4,529
