The Wang paper "An experimental proposal to test the physical effect of the vector potential" proposes an experiment to decide between two interpretations of the Aharonov-Bohm effect:
“the interpretation of electromagnetic potentials”
or
“the interpretation of interaction energy”
The Konopinski paper "What the electromagnetic vector potential describes", takes the interaction energy interpretation and shows the motional scalar potential of the curl-free vector potential:
$$\vec{v} · \vec{A}$$
has the derived electromotive ($\vec{E}_m$) field:
$$\vec{E}_m = - \nabla(\vec{v} · \vec{A}).$$
With force $\vec{F}$ measurable by a test charge $q$ moving with velocity $\vec{v}$:
$$\vec{F} = q ( - \nabla(\vec{v} · \vec{A}) ). $$
The Lorentz force:
$$q \left( -\nabla\phi - \frac{\partial \vec A}{\partial t} + \vec{v} \times (\nabla \times \vec{A}) \right)$$
does not contain this term in its electromotive field. Adding it:
$$q \left( -\nabla\phi - \frac{\partial \vec A}{\partial t} + \vec{v} \times (\nabla \times \vec{A}) - \nabla(\vec{v} \cdot \vec{A})\right)$$
is, by the vector identity of the total derivative:
$$q \left( -\nabla\phi - \frac{D \vec A}{D t} \right).$$
Hence, the Wang paper proposes an experiment that can determine whether
$$\vec{E}_m = -\nabla\phi - \frac{D \vec A}{D t}$$
is true.
This conclusion appears to result from main stream physics but flies in the face of the Lorentz force accepted since the time of Maxwell thence Einstein's 1905 paper "On the Electrodynamics of Moving Bodies".
Apocryphal, non-mainstream apologetics for the $ - \nabla(\vec{v} \cdot \vec{A})$ term maintain it has escaped classical notice because it integrates to 0 around any circuit, and should appear only in open electrodynamics as occur in plasmas and antennas.
It is hard to believe there is a contradiction this long-standing between the recognized classical Lorentz force:
$$\vec{F} = q \left( -\nabla\phi - \frac{\partial \vec A}{\partial t} + \vec{v} \times (\nabla \times \vec{A}) \right)$$ and quantum physics implied by the interaction energy interpretation of the Aharonov-Bohm effect: $$\vec{F} = q \left(-\nabla\phi - \frac{D \vec A}{D t}) = q ( -\nabla\phi - \frac{\partial \vec A}{\partial t} + \vec{v} \times (\nabla\times \vec{A}) - \nabla(\vec{v} \cdot \vec{A})\right)$$ Why is the conclusion reached above, $\vec{E}_m = -\nabla\phi - \frac{D \vec A}{D t}$ incorrect?
This question is not the same as asking, "Why is the conclusion... in conflict with mainstream theory." precisely because it is mainstream theory, apparently, that leads to this conclusion from its empirical grounding in the ABe if one adopts the interaction energy interpretation.
There is either a problem with the interaction energy interpretation of the ABe, or there is a problem with the steps taken in reaching the above conclusion from the interaction energy interpretation of the ABe. Which is it?
