14
The concept in my mind is that an asteroid is on a vector similar to Earth's, but slightly slower (e.g., 50kmh slower). As Earth passes it, it enters the atmosphere at a sharp angle, and since Earth was passing it, it just barely touches down due to Earth's gravity and atmospheric drag.
Given a large asteroid (e.g., 500 meters wide), is there any reason something like this couldn't happen? And, is there any evidence that it has happened?
orokusaki
  • 421
  • 15
If the asteroid is in parallel to the orbit of the earth and at rest it will feel the gravitational attraction and will fall with velocity growing as $g\cdot t^2.$ This force will be there whatever the angle and velocity of the asteroid, centrifugal forces may make it miss the earth in a parabolic orbit, or be caught in an elliptical as the path of the satellites. To avoid falling on the earth with great velocity it would need not only to have a small velocity relative to earth but also an acceleration equal or larger and opposite to the acceleration of gravity.
anna v
  • 236,935
Well, technically, the answer is no as the other answers and comments also say.
The approach speed can not be less than escape velocity. But in order for such a thing to happen, nature has to be really creative and totally in our favor. For example, the asteroid can have a very very lucky combination of these:
  1. The asteroid has right kind and amount of fluid in it that starts jetting out steam at just the right times and right angles.
  2. The asteroid is parachute shaped with appropriate strength and falls at an appropriate angle.
Again, it would be a miracle, so, please do not hit me.
As we may be lucky due to a three body interaction with moon, this is taking the luck to kind of extreme.
kpv
  • 4,529
The answer is yes. All it takes is for the asteroid to come at a tangential velocity equal to the "orbital" velocity of an object "flying" at a height equal to (radius of the earth + radius of asteroid). Of course, there are other effects that are being ignored to simplify the answer.
Guill
  • 2,573
