-2
Mass apart from the amount of material, is also a measure of the inertia of an object, ie. the resistance to change its motion. In zero gravity, does still mass count as the amount of inertia? In other words, the resistance to move a rock is the same in zero gravity and on earth, if there is no friction etc?
ergon
  • 753
Yes, mass has meaning in zero gravity
You are confusing mass with weight. Mass is the "amount of stuff" that is constant in whatever gravitational field the object is in -- even in 0g.
Picture this: mass is used as a measure of inertia, as you say. In math, that's:
$$a = \frac{F}{m}$$
So imagine that if you and something of $m = 1kg$ were on Earth. The object is lying on a flat, frictionless surface. You exert a force of $F = 1 N$ on that mass. Therefore, acceleration you produce is $a = 1 ^m/s^2$.
The important thing to notice is, this is also true in zero gravity. That is, if you wanted to accelerate a $1 kg$ object by $1 ^m/s^2$, whether you are on Earth or in space, you have to apply a $1 N$ force. It's the same everywhere. It resists motion the same way, whether it's on Earth or in space.
markovchain
  • 1,531
It will be much easier to lift and move the mass left/right, up/down in the outer space (zero g, to say). However that should not give an impression that mass does not have inertia in zero g. Inertia is there with the mass, not with the gravity.
The reason it is easier to move stuff in zero g is because you do not have to overcome the continuous pull of gravity. However you would realize the presence of inertia when you try to stop a moving body, or try to accelerate it, or try to spin it around you by attaching it to a string.
kpv
  • 4,529
