I am currently thinking about nuclear fission and realized that I forgot some basic facts I've learned (and understood... at least I thought so) some years ago in school.
I know that electrons are negatively charged, neutrons are neutral and protons are positively charged. I know that same charged particles repels and different charged particles attract each other. Electrons don't fall in the nucleus, because they are flying around it too fast (at least that is a somewhat reasonable way to think about it - I realize that the details are much more complicated). The nucleus is stable, because besides the electric force there is gravity (which was not so important in that context, if I remember it correctly) and the two nuclear forces. Those make sure that the nucleus is stable.
However, what do neutrons change in this context? Are they behaving similar as protons when it comes to the nuclear forces?
Now, what happens when a neutron hits a 238U?
First, there are some misconceptions in your question: the reason electrons don't fall into the nucleus is not because they're 'flying around it too fast' - it is for quantum mechanical reasons (see here). And it is the strong nuclear force that holds nucleons together (not gravity nor the weak nuclear force).
During fission, the neutron is travelling at a high speed and imparts a large amount of energy (several MeV) into the nucleus that it collides with. This causes the nucleus to break apart into two separate lobes. If those two lobes separate by a great enough distance then, due to the fact that the strong nuclear force acts over a very short range, the electrostatic repulsion suddenly dominates and drives the two lobes apart.
lemon
  • 13,320
The nucleus is held together by the balance of two competing forces. The protons due to their charge repel each other, thus there is no nucleus that is just composed by two protons, because the repulsive electrical force dominates and does not allow a binding. There exists the deuteron, though, because a proton and a neutron are held together with the strong force, and for the strong force the proton and neutron are indistinguishable and act as a baryon, with an isotopic spin.
This is a basic characteristic of the table of isotopes, and for large numbers of protons many more neutrons are needed to dilute the repulsive force of the charges of the protons.
The whole nucleus can be described by an effective potential which gives energy levels , a shell model for the available energy locations. This explains the periodic table of elements fairly well, although there are more variations for detail interactions during fission.
anna v
  • 236,935
Neutrons and protons respond identically to the strong force, but only the proton carries electrostatic charge. A simple way to think of this is to imagine that the neutrons can stick to protons without adding any electrostatic repulsion forces to the nucleus. In doing so they help bind the nucleus together, making neutrons a kind of nuclear "glue" strong enough to hold protons together against their mutual electrostatic repulsion.
This is a simplified picture which doesn't work that well when the nucleus gets beyond a certain size. Really big nuclei (uranium, plutonium, etc.) are metastable from a binding standpoint and if perturbed strongly enough will neck down into two smaller globs of nucleons and split in two.
niels nielsen
  • 99,024
